Hello,
I am currently trying to use two LoRa modules to operate an emergency cutdown procedure for a weather balloon. I have gotten the basic examples in Radioheads libraries running shown below to transmit “Hello World” and “And hello back to you” back and forth.
My issue comes when I try to obtain the message that was sent and use it to decide if cutdown is needed on the receive side. Something along the lines of “if the transmitted value is equal to 1234 then cutdown”. I am very new to coding and even more new to radio communications and packet transmission, so I am sorry for any blatant issues. Cutdown procedures have already been created and just rely upon tripping a relay by outputting from an arduino pin, so no help should be needed for that.
I do not understand how to obtain the data that was transmitted and use it in later parts of the program. In all of the examples I’ve found online on forums all that was done was printing to the serial monitor, as far as I can tell. Assistance in storing the transmitted data in a new variable and using it to compare it with a different predetermined string would be amazing.
Sorry for any poor formatting in advance, I will attempt to fix it if there is a problem I am made aware of.
Transmission code
// Feather9x_TX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (transmitter)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
#include <RH_RF95.h>
#define RFM95_INT 3
#define RFM95_CS 4
#define RFM95_RST 2
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 430.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
while (!Serial) {
delay(1);
delay(100);
Serial.println("Feather LoRa TX Test!");
// manual reset
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (!rf95.init()) {
Serial.println("LoRa radio init failed");
while (1);
Serial.println("LoRa radio init OK!");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
// Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
rf95.setTxPower(23, false);
int16_t packetnum = 0; // packet counter, we increment per xmission
delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
Serial.println("Transmitting..."); // Send a message to rf95_server
char radiopacket[20] = "Hello World # ";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending "); Serial.println(radiopacket);
radiopacket[19] = 0;
Serial.println("Sending...");
delay(10);
rf95.send((uint8_t *)radiopacket, 20);
Serial.println("Waiting for packet to complete...");
delay(10);
rf95.waitPacketSent();
// Now wait for a reply
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
Serial.println("Waiting for reply...");
if (rf95.waitAvailableTimeout(1000))
// Should be a reply message for us now
if (rf95.recv(buf, &len))
Serial.print("Got reply: ");
Serial.println((char*)buf);
Serial.print("RSSI: ");
Serial.println(rf95.lastRssi(), DEC);
Serial.println("Receive failed");
Serial.println("No reply, is there a listener around?");
Receiving Code
// Feather9x_RX
// Example sketch showing how to create a simple messaging client (receiver)
// It is designed to work with the other example Feather9x_TX
#include <SPI.h>
#define RFM95_INT 3
#define RFM95_CS 4
#define RFM95_RST 2
#define RF95_FREQ 434.0
// Blinky on receipt
#define LED 13
pinMode(LED, OUTPUT);
while (!Serial) {
delay(1);
delay(100);
Serial.println("Feather LoRa RX Test!");
// manual reset
delay(10);
delay(10);
while (1);
while (1);
if (rf95.available())
// Should be a message for us now
digitalWrite(LED, HIGH);
RH_RF95::printBuffer("Received: ", buf, len);
Serial.print("Got: ");
// Send a reply
uint8_t data[] = "And hello back to you";
rf95.send(data, sizeof(data));
Serial.println("Sent a reply");
digitalWrite(LED, LOW);
