Need help with Rover 5 Robot
I had Rover 5 robot with dimensions below
Gearbox ratio: 86.8:1
Encoder type: Quadrature
Encoder resolution: 1000 state changes per 3 wheel rotations
Actually from above information , I inferred these values below and I don't know how far I am accurate in that , so please need help
Wheel Diameter = 6 in CM
The distance between the center of the treads should be (225mm + 153mm) / 2. This gives 189mm. so
Track Width = 18.9 in CM
333.3 / 2 = 166.65 / 2 = 83.325 , so
CountsPerRevolution = 83.325
So the first question is , are the values computations above right ?
I want to use the information above to determine the odometry of robot so I used the code below but I don't if the code is will give accurate result
                        WheelDiameter = 6;
                        TrackWidth = 18.9;
                        CountsPerRevolution = 83;
                        DistancePerCount = (PI * WheelDiameter) / (double)CountsPerRevolution;
                        RadiansPerCount = DistancePerCount / TrackWidth;
                long deltaLeft = _LeftEncoderTicks - _PreviousLeftEncoderCounts;
                long deltaRight = _RightEncoderTicks - _PreviousRightEncoderCounts;
                double deltaDistance = 0.5f * (double)(deltaLeft + deltaRight) * DistancePerCount;
                double deltaX = deltaDistance * (double)cos(Heading);
                double deltaY = deltaDistance * (double)sin(Heading);
                double deltaHeading = (double)(deltaRight - deltaLeft) * RadiansPerCount;
                X += deltaX;
                Y += deltaY;
                Heading += deltaHeading;
                // limit heading to -Pi <= heading < Pi
                if (Heading > PI)
                        Heading -= TwoPI;
                        if (Heading <= -PI)
                                Heading += TwoPI;
                _PreviousLeftEncoderCounts = _LeftEncoderTicks;
                _PreviousRightEncoderCounts = _RightEncoderTicks;
// Interrupt service routines for the left motor's quadrature encoder
void HandleLeftMotorInterruptA()
  // Test transition; since the interrupt will only fire on 'rising' we don't need to read pin A
  _LeftEncoderBSet = digitalReadFast(c_LeftEncoderPinB);   // read the input pin
  // and adjust counter + if A leads B
  #ifdef LeftEncoderIsReversed
    _LeftEncoderTicks -= _LeftEncoderBSet ? -1 : +1;
  #else
    _LeftEncoderTicks += _LeftEncoderBSet ? -1 : +1;
  #endif
// Interrupt service routines for the right motor's quadrature encoder
void HandleRightMotorInterruptA()
  _RightEncoderBSet = digitalReadFast(c_RightEncoderPinB);   // read the input pin
  #ifdef RightEncoderIsReversed
    _RightEncoderTicks -= _RightEncoderBSet ? -1 : +1;
  #else
    _RightEncoderTicks += _RightEncoderBSet ? -1 : +1;
  #endif
The second question is , is the code above will give accurate result of odometry?
Not a chance.
                        WheelDiameter = 6;
                        TrackWidth = 18.9;
None
of
these
variables
are
typed.
What's up with the stupid indenting?
PaulS:
Not a chance.
                        WheelDiameter = 6;
TrackWidth = 18.9;
None
of
these
variables
are
typed.
thanks
What do you mean by your question ?
Up
Down
UKHeliBob:
Down
Why down ? :roll_eyes:
I need help .
I need help
With what? You posted poorly indented snippets of code. How do you expect us to guess whether you've defined variables with the correct type?
PaulS:
I need help
OK sorry for that . Actually I want to reach to a code without missing any ticks.
code below
#include "Arduino.h"
#include <digitalWriteFast.h>
// Quadrature encoders
// Left encoder
#define c_LeftEncoderInterrupt 0
#define c_LeftEncoderPinA 2
#define c_LeftEncoderPinB 4
#define LeftEncoderIsReversed
volatile bool _LeftEncoderBSet;
volatile long _LeftEncoderTicks = 0;
#define PI 3.14159265
#define TwoPI 6.28318531
// Right encoder
#define c_RightEncoderInterrupt 1
#define c_RightEncoderPinA 3
#define c_RightEncoderPinB 5
volatile bool _RightEncoderBSet;
volatile long _RightEncoderTicks = 0;
    double _DistancePerCount;
        double _radiansPerCount;
        //long _leftEncoderCounts;
        long _PreviousLeftEncoderCounts;
       // long _RightEncoderCounts;
        long _PreviousRightEncoderCounts;
        double X;  // x coord in global frame
        double Y;  // y coord in global frame
        double Heading;  // heading (radians) in the global frame. The value lies in (-PI, PI]
        double WheelDiameter;
                double TrackWidth;
                double CountsPerRevolution;
                double DistancePerCount;
                double RadiansPerCount;
  WheelDiameter = 0.062;
                        TrackWidth = 0.189;
  SetupEncoders();
  delay(100);
void SetupEncoders()
  // Left encoder
  pinMode(c_LeftEncoderPinA, INPUT);      // sets pin A as input
  digitalWrite(c_LeftEncoderPinA, LOW);  // turn on pullup resistors
  pinMode(c_LeftEncoderPinB, INPUT);      // sets pin B as input
  digitalWrite(c_LeftEncoderPinB, LOW);  // turn on pullup resistors
  attachInterrupt(c_LeftEncoderInterrupt, HandleLeftMotorInterruptA, RISING);
  // Right encoder
  pinMode(c_RightEncoderPinA, INPUT);      // sets pin A as input
  digitalWrite(c_RightEncoderPinA, LOW);  // turn on pullup resistors
  pinMode(c_RightEncoderPinB, INPUT);      // sets pin B as input
  digitalWrite(c_RightEncoderPinB, LOW);  // turn on pullup resistors
  attachInterrupt(c_RightEncoderInterrupt, HandleRightMotorInterruptA, RISING);
                X += deltaX;
                Y += deltaY;
                if (Heading > PI)
                        Heading -= TwoPI;
                        if (Heading <= -PI)
                                Heading += TwoPI;
  Serial.print(_LeftEncoderTicks);
  Serial.print("\t");
  Serial.print(_RightEncoderTicks);
  Serial.print("\n");
   Serial.print("\n");
  delay(200);
  #else
  #endif
  #else
  #endif
What, exactly, is attached to these two pins?
PaulS:
I know what the values are. What, physically, is connected to the pins?
PaulS:
only these pins are connected physically to encoder wires as follow. :
#define c_LeftEncoderPinA 2 // connected to signal A of left encoder (White wire )
#define c_LeftEncoderPinB 4 // connected to signal B of left encoder (yellow wire )
#define c_RightEncoderPinA 3 // connected to signal A of right encoder (White wire )
#define c_RightEncoderPinB 5 //connected to signal B of right encoder (yellow wire )
