I am working on a self tuning guitar project (just one string for now), and I need help in how to program the stepper motor to work incrementally depending on my input. I already have the frequency programmed and working. Here is the code I have so far (I'm new here, so sorry if I pasted it wrong). Thank you in advance!
How do you make a stepper motor change incrementally depending on what the frequency is?
#define SAMPLES 128 //Max 128 for Arduino Uno.
#define SAMPLING_FREQUENCY 2048 //Fs = Based on Nyquist, must be 2 times the highest expected frequency.
#define OFFSETSAMPLES 40 //used for calabrating purposes
#define TUNER -3 //Adjust until C3 is 130.50
#include <Stepper.h>
float samplingPeriod;
unsigned long microSeconds;
int X[SAMPLES]; //create vector of size SAMPLES to hold real values
float autoCorr[SAMPLES]; //create vector of size SAMPLES to hold imaginary values
float storedNoteFreq[12] = {130.81, 138.59, 146.83, 155.56, 164.81, 174.61, 185, 196, 207.65, 220, 233.08, 246.94};
int sumOffSet = 0;
int offSet[OFFSETSAMPLES]; //create offset vector
int avgOffSet; //create offset vector
int i, k, periodEnd, periodBegin, period, adjuster, noteLocation, octaveRange;
float maxValue, minValue;
long sum;
int thresh = 0;
int numOfCycles = 0;
float signalFrequency, signalFrequency2, signalFrequency3, signalFrequencyGuess, total;
byte state_machine = 0;
int samplesPerPeriod = 0;
const int stepsPerRevolution = 2048;
Stepper myStepper = Stepper(stepsPerRevolution, 8, 10, 9, 11);
myStepper.setSpeed(5);
Serial.begin(115200); //115200 Baud rate for the Serial Monitor
//Calabration Section
Serial.println("Calabrating. Please do not play any notes during calabration.");
for (i = 0; i < OFFSETSAMPLES; i++)
offSet[i] = analogRead(0); //Reads the value from analog pin 0 (A0), quantize it and save it as a real term.
//Serial.println(offSet[i]); //use this to adjust the sound detection module to approximately half or 512 when no sound is played.
sumOffSet = sumOffSet + offSet[i];
maxValue = 0;
//Prepare to accept input from A0
avgOffSet = round(sumOffSet / OFFSETSAMPLES);
Serial.println("Counting down.");
delay(1000); //pause for 1 seconds
Serial.println("3");
Serial.println("2");
Serial.println("1");
Serial.println("Play your note!");
delay(250); //pause for 1/4 second for reaction time
//Collect SAMPLES samples from A0 with sample period of samplingPeriod
samplingPeriod = 1.0 / SAMPLING_FREQUENCY; //Period in microseconds
for (i = 0; i < SAMPLES; i++)
microSeconds = micros(); //Returns the number of microseconds since the Arduino board began running the current script.
X[i] = analogRead(0); //Reads the value from analog pin 0 (A0), quantize it and save it as a real term.
/*remaining wait time between samples if necessary in seconds */
while (micros() < (microSeconds + (samplingPeriod * 1000000)))
//do nothing just wait
//Autocorrelation Function
for (i = 0; i < SAMPLES; i++) //i=delay
sum = 0;
for (k = 0; k < SAMPLES - i; k++) //Match signal with delayed signal
sum = sum + (((X[k]) - avgOffSet) * ((X[k + i]) - avgOffSet)); //X[k] is the signal and X[k+i] is the delayed version
autoCorr[i] = sum / SAMPLES;
// First Peak Detect State Machine
if (state_machine==0 && i == 0)
thresh = autoCorr[i] * 0.5;
state_machine = 1;
else if (state_machine == 1 && i>0 && thresh < autoCorr[i] && (autoCorr[i]-autoCorr[i-1])>0) //state_machine=1, find 1 period for using first cycle
maxValue = autoCorr[i];
else if (state_machine == 1&& i>0 && thresh < autoCorr[i-1] && maxValue == autoCorr[i-1] && (autoCorr[i]-autoCorr[i-1])<=0)
periodBegin = i-1;
state_machine = 2;
numOfCycles = 1;
samplesPerPeriod = (periodBegin - 0);
period = samplesPerPeriod;
adjuster = TUNER+(50.04 * exp(-0.102 * samplesPerPeriod));
signalFrequency = ((SAMPLING_FREQUENCY) / (samplesPerPeriod))-adjuster; // f = fs/N
else if (state_machine == 2 && i>0 && thresh < autoCorr[i] && (autoCorr[i]-autoCorr[i-1])>0) //state_machine=2, find 2 periods for 1st and 2nd cycle
else if (state_machine == 2&& i>0 && thresh < autoCorr[i-1] && maxValue == autoCorr[i-1] && (autoCorr[i]-autoCorr[i-1])<=0)
periodEnd = i-1;
state_machine = 3;
numOfCycles = 2;
samplesPerPeriod = (periodEnd - 0);
signalFrequency2 = ((numOfCycles*SAMPLING_FREQUENCY) / (samplesPerPeriod))-adjuster; // f = (2*fs)/(2*N)
maxValue = 0;
else if (state_machine == 3 && i>0 && thresh < autoCorr[i] && (autoCorr[i]-autoCorr[i-1])>0) //state_machine=3, find 3 periods for 1st, 2nd and 3rd cycle
else if (state_machine == 3&& i>0 && thresh < autoCorr[i-1] && maxValue == autoCorr[i-1] && (autoCorr[i]-autoCorr[i-1])<=0)
periodEnd = i-1;
state_machine = 4;
numOfCycles = 3;
signalFrequency3 = ((numOfCycles*SAMPLING_FREQUENCY) / (samplesPerPeriod))-adjuster; // f = (3*fs)/(3*N)
//Result Analysis
if (samplesPerPeriod == 0)
Serial.println("Hmm..... I am not sure. Are you trying to trick me?");
//prepare the weighting function
total = 0;
if (signalFrequency !=0)
total = 1;
if(signalFrequency2 !=0)
total = total + 2;
if (signalFrequency3 !=0)
total = total + 3;
//calculate the frequency using the weighting function
signalFrequencyGuess = ((1/total) * signalFrequency) + ((2/total) * signalFrequency2) + ((3/total) * signalFrequency3); //find a weighted frequency
Serial.print("The note you played is approximately ");
Serial.print(signalFrequencyGuess); //Print the frequency guess.
Serial.println(" Hz.");
//find octave range based on the guess
octaveRange=3;
while (!(signalFrequencyGuess >= storedNoteFreq[0]-7 && signalFrequencyGuess <= storedNoteFreq[11]+7 ))
for(i = 0; i < 12; i++)
storedNoteFreq[i] = 2 * storedNoteFreq[i];
octaveRange++;
//Find the closest note
minValue = 10000000;
noteLocation = 0;
for (i = 0; i < 12; i++)
if(minValue> abs(signalFrequencyGuess-storedNoteFreq[i]))
minValue = abs(signalFrequencyGuess-storedNoteFreq[i]);
noteLocation = i;
//Print the note
Serial.print("I think you played ");
if(noteLocation==0)
Serial.print("C");
else if(noteLocation==1)
Serial.print("C#");
else if(noteLocation==2)
Serial.print("D");
else if(noteLocation==3)
Serial.print("D#");
else if(noteLocation==4)
Serial.print("E");
else if(noteLocation==5)
Serial.print("F");
else if(noteLocation==6)
Serial.print("F#");
else if(noteLocation==7)
Serial.print("G");
else if(noteLocation==8)
Serial.print("G#");
else if(noteLocation==9)
Serial.print("A");
else if(noteLocation==10)
Serial.print("A#");
else if(noteLocation==11)
Serial.print("B");
Serial.println(octaveRange);
//Stop here. Hit reset button on Arduino to restart
while (1);
