I was trying to read from an ADC, if I use the serial monitor, I can see the numbers jumping between -134 to -140. If I check the Serial Plotter ,I can only see a straight line on top of the window without any graduation on left side.
just simply read from a ADS1015 ADC. I basically used the sample code from their company.
I found that if the output contains negative value only, there will be this problem ; Positive value only, no problem ; negative and positive value mixed, the graduation will be adjusted by the positive values only.
Is this a bug or something?
Another problem is , when the data values changes greatly, the plotter will back to work again, and when the data start to switch between two negative stable values, everythins will gone.
