Need help with servo ASAP!
My servo was working perfectly up to this point. All of the wires hooked up to my arduino are correct, the only thing I can think of is sometimes my serial port changes by itself automatically. This is my sketch:
Arduino Servo Scissor sketch
#include <Servo.h>
Servo servoMain; // Define our Servo
   servoMain.attach(6); // servo on digital pin 6
   servoMain.write(45);  // Turn Servo Left to 45 degrees
   delay(1000);          // Wait 1 second
   servoMain.write(0);   // Turn Servo Left to 0 degrees
   servoMain.write(90);  // Turn Servo back to center position (90 degrees)
   delay(0);          // Wait 1 second
   servoMain.write(135); // Turn Servo Right to 135 degrees
   delay(500);          // Wait 1 second
   servoMain.write(180); // Turn Servo Right to 180 degrees
Please help! Thank you!
No nothing to do with it.
We need a lot more information.
What actually happens now?
How are you powering the servos?
Have you put more load on them?
Sorry about that. There is more load on the servo, the servo is a 90 degree one, the arduino itself blinks, and the code reads through but the servo doesn't work. At the moment I am using my computer to power the arduino, but will be using an outlet later on.
I've just replaced the servo I was using with a new one and it's the same result. Both don't work, and i'm unsure of the cause.
What does that mean?
katkatkattkac:
How are you powering the servo?
What I mean when I say the "code reads through" is that it uploads normally, and the servo is powered by my laptop as well, it's attached to a breadboard. I'm sorry for not being clear, I'm still fairly new at this.
Thanks.
It is not normal to power servos from the USB connector of the computer. Depending on the servo's size this can pull too much current.
However it sounds like your wiring has gone wrong. Are you using solderless bread board? This is not a very good method of construction and wiring that looks like it is making contact often isn't.
So get your multimeter out and measure the voltage across the servo's supply at the servo motor itself.
The other thing to try is to use an other pin to control the servo as you might have damaged pin 6.
Thank you, I'll try that.
katkatkattkac:
Powering the servo from the Arduino's power supply is not recommended, although you can sometimes get away with it for small servos that are only lightly loaded. If the problem started when you increased the load on the servo it's quite likely you're just overloading the Arduino. You could try disconnecting the load from the servo and see whether it works OK when it can move freely - if the servo works OK like that it confirms that this is a power supply problem. The solution is to provide a separate power supply for the servo, for example a separate battery pack or regulated wall wart. The battery pack or wall wart power supply ground needs to be connected to the Arduino's ground.
