could someone help me combine these two sketches
I am new to this and would greatly appreciate some help
what I would like to do is trigger the random servo movement with the pir and only move servos when pir triggers my audio
* //making sense of the Parallax PIR sensor's output
* Switches a LED according to the state of the sensors output pin.
* Determines the beginning and end of continuous motion sequences.
* @author: Kristian Gohlke / krigoo (_) gmail (_) com / http://krx.at
* @date: 3. September 2006
* kr1 (cleft) 2006
* released under a creative commons "Attribution-NonCommercial-ShareAlike 2.0" license
* http://creativecommons.org/licenses/by-nc-sa/2.0/de/
* The Parallax PIR Sensor is an easy to use digital infrared motion sensor module.
* (http://www.parallax.com/detail.asp?product_id=555-28027)
* The sensor's output pin goes to HIGH if motion is present.
* However, even if motion is present it goes to LOW from time to time,
* which might give the impression no motion is present.
* This program deals with this issue by ignoring LOW-phases shorter than a given time,
* assuming continuous motion is present during these phases.
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 1;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 3; //the digital pin connected to the PIR sensor's output
int ledPin = 13;
int mp3Pin = 2;
//SETUP
void setup(){
Serial.begin(38400);
pinMode(pirPin, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(mp3Pin, OUTPUT); //set mp3Pin as an output
digitalWrite(pirPin, LOW);
digitalWrite(mp3Pin, LOW); //set mp3Pin to low ("off")
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
void loop(){
if(digitalRead(pirPin) == HIGH){
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
digitalWrite(mp3Pin, HIGH); //send a signal on the mp3Pin to have the relay trigger the sound
delay(2); //wait
digitalWrite(mp3Pin, LOW); //bring the mp3Pin back low so the relay closes and doesn't loop the sound
delay(15000);
delay(2);
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(100);
* ScaryShiftServoEyeballs.pde --
* Get two eyeballs, hook a servo to each one,
* then mount that on a 'head' and connect a servo to that.
* This sketch will make the eyes and head "look around" in a shifty fashion.
* Add sensors to make it look at things!
* 2009, Tod E. Kurt, http://todbot.com/blog/
#include <Servo.h>
Servo servoHead;
Servo servoEyeL;
Servo servoEyeR;
int posHead;
int posEye;
int posHdest, posEdest;
int wait;
int rate = 2;
servoHead.attach(5);
servoEyeL.attach(6);
servoEyeR.attach(7);
posHdest = posHead = 90;
posEdest = posEye = 90;
if( wait == 0 ) {
posHdest = random(70,110); // move had between 70-110 degrees
posEdest = random(40,140); // move eyes between 40-140 degrees
wait = random(150,450); // between 1.5 secs & 4.5 secs
else {
posHead = slew_servo( posHead, posHdest, rate);
posEye = slew_servo( posEye, posEdest, rate);
wait--;
servoHead.write( posHead );
servoEyeL.write( posEye );
servoEyeR.write( posEye );
delay(10);
// return new pos from current pos, dest and rate
int slew_servo( int pos, int dest, int rate)
int diff = pos - dest;
if( diff == 0 ) return pos;
else if( diff > -rate ) pos++;
else if( diff < rate ) pos--;
if( diff > 0 ) pos -= rate;
else if( diff < 0 ) pos += rate;
return pos;
Moderator edit: tags added.
