Need help with setpoint via serial m' (with pid or without)
Hi :slight_smile:
I have projact with Dht11 sensor. for meanwhile is showing only the temp from the sensor (smple code) i know how to trun on and off the relay via the temp setpoint (setpoint = 30; - for exmple)
But how can i set or change the setpoint via serial monitor (not buttons)?
I need sample code or the specific code lines.
thanks again
A.K
I need sample code
Serial input basics would be a good place to start.
UKHeliBob:
Thanks - I will chack it :slight_smile:
but for exmple - how can i customize this code to fit my requirement?
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//These setpoints roughly correspond to 260, 295, 310, 330, 350C
//Based on one experiment cooling down...
//Your Iron may Vary
int setpoints[] = {70, 200, 250, 340, 450};
int currentSetpoint = 0; //Always start at the coolest temperature.
int upButton = 5;
int downButton = 6;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,1,0.1,0.5, DIRECT);
  pinMode(upButton, INPUT);
  pinMode(downButton, INPUT);
  //initialize the variables we're linked to
  Input = analogRead(0);
  Setpoint = setpoints[currentSetpoint];
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  myPID.Compute();
  Serial.print("Setpoint = ");
  Serial.print(Setpoint, DEC);
  Serial.print(" Temp Reading = ");
  Serial.print(Input, DEC);
  Serial.print(" Output PWNM Value");
  Serial.println(Output, DEC);
  analogWrite(3,Output);
  delay(200);
  //Now to set an appropriate temperature setpoint
  //(and make sure we stay within the bounds of the array)
  if(digitalRead(5)==1) {
    currentSetpoint++;
    if(currentSetpoint > 4) {
        currentSetpoint=4;
  } else if (digitalRead(6) == 1) {
    currentSetpoint--;
    if(currentSetpoint < 0) {
        currentSetpoint=0;
Replace the reading of buttons and increment/decrement actions on the set point with a call to a function that reads serial input and converts it to a number to be used as the set point,
