Need help with shortening repeating code
I need help in finishing a project where im using my arduino uno to go through a series of commands to operate a remote. The issue im having is to shortening my code as alot of the buttons will be "pressed" repeatedly. Im not sure how to reference it so I can use a much smaller phrase
  // Down Button Press
  digitalWrite(Dpin, HIGH);   // Press Button
  delay(250);                  // waits for .25 sec
  digitalWrite(Dpin, LOW);   // releases button
  // Up Button Press
  digitalWrite(Upin, HIGH);   // Press Button
  digitalWrite(Upin, LOW);   // releases button
  // Left Button Press
  digitalWrite(Lpin, HIGH);        //Press Button
  delay(250);                  // Wait for .25 sec
  digitalWrite(Lpin, LOW);     // Releases Button
  // Right Button Press
  digitalWrite(Rpin, HIGH);   // Press Button
  digitalWrite(Rpin, LOW);   // releases button
  //Back Button Press
  digitalWrite(BKpin, HIGH);   // Press Button
  digitalWrite(BKpin, LOW);   // releases button
  //Select/Ok Button Press
  //Home Button Press
  digitalWrite(Hpin, HIGH);   // Press Button
  digitalWrite(Hpin, LOW);   // releases button
Look up arrays and for loops.
something this simple you can call as a function
const byte Dpin = 2;
const byte Upin = 3;
const byte Lpin = 4;
const byte Rpin = 5;
const byte BKpin = 6;
const byte Hpin = 7;
pinMode(Dpin,OUTPUT);
pinMode(Upin,OUTPUT);
pinMode(Lpin,OUTPUT);
pinMode(Rpin,OUTPUT);
pinMode(BKpin,OUTPUT);
pinMode(Hpin,OUTPUT);
pressAndRelease(Dpin);
pressAndRelease(Upin);
pressAndRelease(Lpin);
pressAndRelease(Rpin);
pressAndRelease(BKpin);
pressAndRelease(Hpin);
void pressAndRelease(int thisPin){
   digitalWrite(thisPin, HIGH);   // Press Button
  digitalWrite(thisPin, LOW);   // releases button
@Modme09, you may find some useful concepts in Planning and Implementing a Program
...R
If some day you want to run various sequences of button presses you can use arrays and pointers to allow the sequences to be defined by data rather than by code:
const byte PinList[] = {Dpin, Upin, Lpin, Rpin, BKpin, Hpin};  // List all output pins for setup()
const byte Sequence[] = {Dpin, Upin, Lpin, Rpin, BKpin, Hpin};  // A sequence to press in order
  for (int i = 0; i < sizeof PinList; i++)
    pinMode(PinList[i], OUTPUT);
  RunSequence(Sequence, sizeof Sequence);
void RunSequence(const byte *seq, size_t count) {
  for (int i = 0; i < count; i++)
    pressAndRelease(seq[i]);
void pressAndRelease(int thisPin) {
Thank you all for your help I will be rewriting my code soon with functions as mentioned above. As of now I have taken the time to write all 1970 lines of my original redundant code but on the bright side it did work wonderfully, but with functions itll be reduced by 2/3.
