need help with simplyscan3d
Hi all need some help with this build, as you can see it a mash up of a couple of different 3d scanners, the saurduscan and the fabscan. I am using the ULN 2003 stepper controller. I am trying to modify the code to suit and amusing the guide by Francis Engelmann - http://www.ardumotive.com/arduino-3d-scanner.html. He has supplied some extra code to make this workwithout the fabscan shield
Apparently I should add this, but I am not sure where,
#include <Stepper.h>
const int stepsPerRevolution = 24;  // change this to fit the number of steps per revolution
// for your motor
Stepper myStepper(stepsPerRevolution, 10, 11,8,9);
also “Replace step() function with:”
void step()
  myStepper.setSpeed(1);
  myStepper.step(1);
I am not sure what code I have to replace.
here is the code
// FabScan - http://hci.rwth-aachen.de/fabscan
//  Created by Francis Engelmann on 7/1/11.
//  Copyright 2011 Media Computing Group, RWTH Aachen University. All rights reserved.
//  Chngelog:
//  R. Bohne 29.01.2013: changed pin mapping to Watterott FabScan Arduino Shield
//  R. Bohne 30.12.2013: added pin definitions for stepper 4 --> this firmware supports the new FabScan Shield V1.1, minor syntax changes. Steppers are now disabled at startup.
//  R. Bohne 12.03.2014: renamed the pins 14..19 to A0..A5 (better abstraction for people who use Arduino MEGA, etc.)
#define LIGHT_PIN A3
#define LASER_PIN A4
#define MS_PIN    A5
//Stepper 1 as labeled on Shield, Turntable
#define ENABLE_PIN_0  2
#define STEP_PIN_0    3
#define DIR_PIN_0     4
//Stepper 2, Laser Stepper
#define ENABLE_PIN_1  5
#define STEP_PIN_1    6
#define DIR_PIN_1     7
//Stepper 3, currently unused
#define ENABLE_PIN_2  11
#define STEP_PIN_2    12
#define DIR_PIN_2     13
//Stepper 4, currently unused
#define ENABLE_PIN_3  A0
#define STEP_PIN_3    A1
#define DIR_PIN_3     A2
#define TURN_LASER_OFF      200
#define TURN_LASER_ON       201
#define PERFORM_STEP        202
#define SET_DIRECTION_CW    203
#define SET_DIRECTION_CCW   204
#define TURN_STEPPER_ON     205
#define TURN_STEPPER_OFF    206
#define TURN_LIGHT_ON       207
#define TURN_LIGHT_OFF      208
#define ROTATE_LASER        209
#define FABSCAN_PING        210
#define FABSCAN_PONG        211
#define SELECT_STEPPER      212
#define LASER_STEPPER       11
#define TURNTABLE_STEPPER   10
//the protocol: we send one byte to define the action what to do.
//If the action is unary (like turnung off the light) we only need one byte so we are fine.
//If we want to tell the stepper to turn, a second byte is used to specify the number of steps.
//These second bytes are defined here below.
#define ACTION_BYTE         1    //normal byte, first of new action
#define LIGHT_INTENSITY     2
#define TURN_TABLE_STEPS    3
#define LASER1_STEPS        4
#define LASER2_STEPS        5
#define LASER_ROTATION      6
#define STEPPER_ID          7
int incomingByte = 0;
int byteType = 1;
int currStepper;
//current motor: turn a single step
void step()
 if(currStepper == TURNTABLE_STEPPER){
   digitalWrite(STEP_PIN_0, LOW);
 }else if(currStepper == LASER_STEPPER){
   digitalWrite(STEP_PIN_1, LOW);
 delay(3);
   digitalWrite(STEP_PIN_0, HIGH);
   digitalWrite(STEP_PIN_1, HIGH);
 delay(3);
//step the current motor for <count> times
void step(int count)
  for(int i=0; i<count; i++){
    step();
  // initialize the serial port
   pinMode(LASER_PIN, OUTPUT);
   pinMode(LIGHT_PIN, OUTPUT);
   pinMode(MS_PIN, OUTPUT);
   digitalWrite(MS_PIN, HIGH);  //HIGH for 16microstepping, LOW for no microstepping
  pinMode(ENABLE_PIN_0, OUTPUT);
  pinMode(DIR_PIN_0, OUTPUT);
  pinMode(STEP_PIN_0, OUTPUT);
  pinMode(ENABLE_PIN_1, OUTPUT);
  pinMode(DIR_PIN_1, OUTPUT);
  pinMode(STEP_PIN_1, OUTPUT);
  pinMode(ENABLE_PIN_2, OUTPUT);
  pinMode(DIR_PIN_2, OUTPUT);
  pinMode(STEP_PIN_2, OUTPUT);
  pinMode(ENABLE_PIN_3, OUTPUT);
  pinMode(DIR_PIN_3, OUTPUT);
  pinMode(STEP_PIN_3, OUTPUT);
 //disable all steppers at startup
 digitalWrite(ENABLE_PIN_0, HIGH);  //HIGH to turn off
 digitalWrite(ENABLE_PIN_1, HIGH);  //HIGH to turn off
 digitalWrite(ENABLE_PIN_2, HIGH);  //LOW to turn on
 digitalWrite(ENABLE_PIN_3, HIGH);  //LOW to turn on
 digitalWrite(LIGHT_PIN, LOW); //turn light off
 digitalWrite(LASER_PIN, HIGH); //turn laser on
 Serial.write(FABSCAN_PONG); //send a pong back to the computer so we know setup is done and that we are actually dealing with a FabScan
 currStepper = TURNTABLE_STEPPER;  //turntable is default stepper
  if(Serial.available() > 0){
    incomingByte = Serial.read();
    switch(byteType){
      case ACTION_BYTE:
          switch(incomingByte){    //this switch always handles the first byte
            //Laser
            case TURN_LASER_OFF:
              digitalWrite(LASER_PIN, LOW);    // turn the LASER off
            case TURN_LASER_ON:
              digitalWrite(LASER_PIN, HIGH);   // turn the LASER on
            case ROTATE_LASER: //unused
              byteType = LASER_ROTATION;
            //TurnTable
            case PERFORM_STEP:
              byteType = TURN_TABLE_STEPS;
            case SET_DIRECTION_CW:
                digitalWrite(DIR_PIN_0, HIGH);
                digitalWrite(DIR_PIN_1, HIGH);
            case SET_DIRECTION_CCW:
                digitalWrite(DIR_PIN_0, LOW);
                digitalWrite(DIR_PIN_1, LOW);
            case TURN_STEPPER_ON:
                digitalWrite(ENABLE_PIN_0, LOW);
                digitalWrite(ENABLE_PIN_1, LOW);
            case TURN_STEPPER_OFF:
            case TURN_LIGHT_ON:
              byteType = LIGHT_INTENSITY;
            case TURN_LIGHT_OFF:
            case FABSCAN_PING:
              delay(1);
            case SELECT_STEPPER:
              byteType = STEPPER_ID;
       case LIGHT_INTENSITY:       //after this point we take care of the second byte if one is sent
          analogWrite(LIGHT_PIN, incomingByte);
          byteType = ACTION_BYTE;  //reset byteType
        case TURN_TABLE_STEPS:
          step(incomingByte);
        case STEPPER_ID:
          Serial.write(incomingByte);
          currStepper = incomingByte;
Put this bit at the very start of your program.
The function should be placed at the end of the file, then remove the existing step function.
thanks for your help, for the step function, I am unsure which bits to remove, I can see where it starts( i think) but am unsure where that part ends
Put your cursor just after the first { and the matching } will have a box drawn round it. Remove all the lines including the two with { and } on them and the void step() line.
Just looked at the code in detail and it is written using the overload technique. In my opinion this is bad. It means there are two functions with the same name. So once you have removed that function put the new one back in the same place.
thanks grumpy will try that
