Hello there, currently im developing an arduino project about Smart Blind Sticks with gps and gsm modules. I want it to be rechargeable with a power bank kit. So my current components are a powerbank kit, 3.7V 120mAh battery, hcsr04 ultrasonic sensor, Sim800L gsm module, Neo 6M GPS module, Arduino nano, 4x4 pin tact switches, buzzer, arduino vibration motor. It has 3 alert modes which can be choosed by 3 buttons i placed on circuit. And also i want to integrate gsm and gps module with a button so that when i press the button it will send the desired phone number a sms with the coordinates of the disabled person. Ultrasonic sensor will calculate the distance and when a obstacle is closer then 100 cm it will alert the user. I present you my current code;
` #include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define button1 2 // Button for Alarm mode
#define button2 3 // Button for Alarm and Vibration modes
#define button3 4 // Button for Vibration mode
#define button4 5 // Button for GPS location
#define buzzer 6 // Buzzer pin for alarm
#define motor 7 // Vibration motor pin
#define echopin 8 // Echo pin of the ultrasonic sensor
#define trigpin 9 // Trigger pin of the ultrasonic sensor
#define gsmSerialTxPin 10 // Serial data output pin of GSM module
#define gsmSerialRxPin 11 // Serial data input pin of GSM module
SoftwareSerial gsmSerial(gsmSerialTxPin, gsmSerialRxPin); // Serial port definition for GSM module
TinyGPSPlus gps; // Object for reading GPS data
int Alarm = 1, Vibrator = 1; // Default: Alarm and Vibration modes are enabled
int cm; // Distance value
Serial.begin(9600); // Start serial communication
gsmSerial.begin(9600); // Start GSM module
pinMode(button1, INPUT_PULLUP); // Set button 1 as input
pinMode(button2, INPUT_PULLUP); // Set button 2 as input
pinMode(button3, INPUT_PULLUP); // Set button 3 as input
pinMode(button4, INPUT_PULLUP); // Set button 4 as input
pinMode(buzzer, OUTPUT); // Set buzzer pin as output
pinMode(motor, OUTPUT); // Set vibration motor pin as output
pinMode(trigpin, OUTPUT); // Set trigger pin of ultrasonic sensor as output
pinMode(echopin, INPUT); // Set echo pin of ultrasonic sensor as input
if (digitalRead(button1) == 0) Alarm = 1, Vibrator = 0; // Only Alarm mode
if (digitalRead(button2) == 0) Alarm = 1, Vibrator = 1; // Alarm and Vibration modes
if (digitalRead(button3) == 0) Alarm = 0, Vibrator = 1; // Only Vibration mode
if (digitalRead(button4) == 0) sendGPSLocation(); // Send GPS location
digitalWrite(trigpin, LOW); // Send low signal to trigger pin
delayMicroseconds(2);
digitalWrite(trigpin, HIGH); // Send high signal
delayMicroseconds(10); // Wait for 10 microseconds
long ultra_time = pulseIn(echopin, HIGH); // Measure duration of high signal on echo pin
cm = ultra_time / 29 / 2; // Calculate distance
if (cm >= 20 && cm <= 100) {
int d = map(cm, 20, 100, 20, 2000); // Map the distance
if (Alarm == 1) digitalWrite(buzzer, HIGH); // Turn on buzzer
if (Vibrator == 1) digitalWrite(motor, HIGH); // Turn on vibration motor
delay(100);
digitalWrite(buzzer, LOW); // Turn off buzzer
digitalWrite(motor, LOW); // Turn off vibration motor
delay(d);
if (cm < 20) {
if (cm > 100) {
delay(10); // Wait for 10 milliseconds
void sendGPSLocation() {
if (gps.location.isValid()) {
String latitude = String(gps.location.lat(), 6);
String longitude = String(gps.location.lng(), 6);
String message = "Location: Google Maps" + latitude + "," + longitude;
gsmSerial.println("AT+CMGF=1"); // Set SMS text mode
delay(100);
gsmSerial.println("AT+CMGS=\"+905555555555\""); // Enter recipient's phone number
delay(100);
gsmSerial.println(message); // Send message
And the question is; is there any missing points in my code and any advices to improve it ? Also if you can help me with the connections and circuit diagram i couldn't appriciate it more. Thank you for helping fellow developers!
