Need help with Smartblind Servo not working
Hello,
I’m new with all this so please bare with me.
I found a sketch on the internet to control my blinds with servo but it always turn in the same direction . I’m using a nodemcu lolin v3 and Servo mg996R that i modified for continious rotation (this part is working fine).
Can someone take a look at my sketch and tell me what could be wrong. The servo only turing in 1 direction…
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <Servo.h>
#define WLAN_SSID       "MY SSID"
#define WLAN_PASS       "MY PASSWORD"
MDNSResponder mdns;
ESP8266WebServer server(80);
Servo myservo;
int pos = 0;
int state = 0;
int prevstate = 0;
int dirc = 0;
int servoPin = D0; //CHANGE TO WHATEVER PIN YOUR USING
String webPage = "";
void setup(void) {
  webPage += "<h1>ESP8266 Web Server</h1><p>Blinds <a href=\"open\"><button>OPEN</button></a>&nbsp;<a href=\"close\"><button>CLOSE</button></a></p>";
  delay(2000);
  Serial.println("Blind Startup Sequence");
  delay(2000);
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  // Set a static IP (optional)
//  IPAddress ip(192, 168, 1, 142);
//  IPAddress gateway(192, 168, 1, 1);
//  IPAddress subnet(255, 255, 255, 0);
//  WiFi.config(ip, gateway, subnet);
  // End of set a static IP (optional)
  delay(2000);
  int i = 0;
    delay(2000);
    Serial.print(".");
    ESP.wdtFeed();
    if (i > 40)                                        // Try 40 times to connect to Wifi
      Serial.print("Restarting Wifi"); ESP.reset();    // Reset Wifi stack if more than 40 trys
    i++;
    // Set a static IP retry (optional)
    // End of set a static IP retry (optional)
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  if (mdns.begin("esp8266", WiFi.localIP())) {
    Serial.println("MDNS responder started");
  server.on("/", []() {
    server.send(200, "text/html", webPage);
  server.on("/open", []() {
    Serial.println("HTTP OPEN COMMAND RECEIVED");
    dirc = 0;  // direction for servo to run
    state = 2; // sets current state
  server.on("/close", []() {
    Serial.println("HTTP CLOSE COMMAND RECEIVED");
    dirc = 180; // direction for servo to run
    state = 1;  // sets current state
  server.begin();
  Serial.println("HTTP server started");
void servo_move() {
  Serial.println("State Change. Rotating Servo");
  if ( dirc == 180) {
    myservo.attach(servoPin);              // energize servo
    delay(50);
    for (pos = 0; pos <= 90; pos += 1) {   // goes from 0 degrees to 90 degrees in steps of 1 degree CHANGE 90 TO MATCH ANGLE OF TILT DESIRED
      myservo.write(pos);                  // tell servo to go to position in variable 'pos'
      delay(30);                           // waits 30ms between each degree to slow rotation speed
    delay(50);
    myservo.detach();                      // movement finished so detach servo to conserve power
  else if (dirc == 0) {
    delay(50);
    for (pos = 90; pos >= 0; pos -= 1) {   // goes from 90 degrees to 0 degrees in steps of 1 degree CHANGE 90 TO MIRROR ANGLE OF TILT DESIRED ABOVE
    delay(50);
  Serial.println("Returning to main loop");
  return;
void loop(void) {
  if (state != prevstate) {
    Serial.println("State change!");
    servo_move();
  prevstate = state;
  server.handleClient();
From Arduino - ServoWrite
On a continuous rotation servo, this will set the speed of the servo (with 0 being full-speed in one direction, 180 being full speed in the other, and a value near 90 being no movement).
Now look at your code that controls the servo. It only ever writes values between 0 and 90. If you want it to turn the other direction, you need to use the values between 90 and 180!
It's a good idea to write a simple sketch to make sure you understand how to work with the servo before adding the extra complexity of the network communication. Write a sketch that only turns the servo one way and then another. You could adapt File > Examples > Servo > Sweep for that purpose.
