Need Help With Sound Function
Hello,
I am doing a Radio Alarm Clock and I am stuck on why my alarm clock is not playing any sound. I am using a TEA5767 and a PAM8403. This is my code:`
#include <Wire.h>
#include <RTClib.h>
#include <TEA5767Radio.h>
#include <SoftwareSerial.h>
//#include <TEA5767.h>
LiquidCrystal_I2C lcd(0x3f,20,4); // Display  I2C 20 x 4
RTC_DS1307 RTC;
//#define RTC_DS1307 RTC_I2C_ADDRESS 0x68;
//#define TEA5767Radio_I2C_ADDRESS 0x60;
TEA5767Radio radio = TEA5767Radio();
//************Button*****************//
int P1=6; // Button SET MENU'
int P2=7; // Button +
int P3=8; // Button -
int P4=9; // SWITCH Alarm
int MEMO = 5;
int Rswitch = 11;
int ROnOff = 12;
//**************Alarm***************//
#define LED 13
#define buzzer 10
//************Variables**************//
int hourupg;
int minupg;
int yearupg;
int monthupg;
int dayupg;
int menu =0;
int setAll =0;
float frequency = 0;
int RadioState = 0; // Radio Off
float count = 0;
float memory = 0;
float memory0 = 93.50; //red fm
float memory1 = 98.30;   // radio mirchi
float memory2 = 91.10; // Radio city
float memory3 = 102.00;//FM rainbow
float memory4 = 87.50;// Air TVM DTH
uint8_t alarmHours = 0, alarmMinutes = 0;  // Holds the current alarm time
  Wire.begin();
  RTC.begin();
  lcd.begin();
  lcd.backlight();
  lcd.clear();
  pinMode(P1,INPUT_PULLUP); s
  pinMode(P2,INPUT_PULLUP);
  pinMode(P3,INPUT_PULLUP);
  pinMode(P4,INPUT_PULLUP);
  pinMode(LED,OUTPUT);
  pinMode(buzzer, OUTPUT); // Set buzzer as an output
  pinMode(Rswitch,INPUT_PULLUP);
  pinMode(ROnOff,OUTPUT);
  pinMode(MEMO,INPUT_PULLUP);
  printAllOff();
  frequency = memory0;                       //starting frequency
  radio.setFrequency(frequency);
  lcd.setCursor(0,3);
  lcd.print("RED FM:");
  lcd.setCursor(14, 3);
  lcd.print(frequency);
//  Serial.begin(9600);
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // Set the date and time at compile time
    RTC.adjust(DateTime(__DATE__, __TIME__));
  // RTC.adjust(DateTime(__DATE__, __TIME__)); //removing "//" to adjust the time
    // The default display shows the date and time
  int menu=0;
// check if you press the SET button and increase the menu index
  if(digitalRead(P1)== LOW)
   menu=menu+1;
  if((digitalRead(P2)== LOW)&&(digitalRead(P3)== LOW))
    DisplaySetHourAll();
    DisplaySetMinuteAll();
    lcd.clear();
    lcd.setCursor(5,0);
    lcd.print("ALARM");
    lcd.setCursor(5,1);
    lcd.print(alarmHours, DEC);
    lcd.print(":");
    lcd.print(alarmMinutes, DEC);
    lcd.clear();
  if (menu==0)
     DisplayDateTime(); // void DisplayDateTime
     Alarm(); // Alarm control
  if (digitalRead (Rswitch) == LOW)
   RadioState = RadioState +1;
  if (RadioState == 0)
   digitalWrite ( ROnOff , LOW); // Radio Off
    PrintRadioOff();
   delay(50);
  if (RadioState == 1)
   digitalWrite ( ROnOff , HIGH); // Radio On
   Radio();
   delay(50);
  if (RadioState == 3)
   RadioState = 0;
   delay(50);
  if (menu==1)
    DisplaySetHour();
  if (menu==2)
    DisplaySetMinute();
  if (menu==3)
    DisplaySetYear();
  if (menu==4)
    DisplaySetMonth();
  if (menu==5)
    DisplaySetDay();
  if (menu==6)
    StoreAgg();
    menu=0;
    frequencyUpdate();
    delay(20);
void DisplayDateTime ()
// We show the current date and time
  DateTime now = RTC.now();
  lcd.setCursor(0, 1);
  lcd.print("Hour : ");
  if (now.hour()<=9)
    lcd.print("0");
  lcd.print(now.hour(), DEC);
  hourupg=now.hour();
  lcd.print(":");
  if (now.minute()<=9)
    lcd.print("0");
  lcd.print(now.minute(), DEC);
  minupg=now.minute();
  lcd.print(":");
  if (now.second()<=9)
    lcd.print("0");
  lcd.print(now.second(), DEC);
  lcd.setCursor(0, 0);
  lcd.print("Date : ");
  if (now.day()<=9)
    lcd.print("0");
  lcd.print(now.day(), DEC);
  dayupg=now.day();
  lcd.print("/");
  if (now.month()<=9)
    lcd.print("0");
  lcd.print(now.month(), DEC);
  monthupg=now.month();
  lcd.print("/");
  lcd.print(now.year(), DEC);
  yearupg=now.year();
void DisplaySetHour()
// time setting
  lcd.clear();
  if(digitalRead(P2)==LOW)
    if(hourupg==23)
      hourupg=0;
      hourupg=hourupg+1;
   if(digitalRead(P3)==LOW)
    if(hourupg==0)
      hourupg=23;
      hourupg=hourupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set time:");
  lcd.setCursor(0,1);
  lcd.print(hourupg,DEC);
  delay(200);
void DisplaySetMinute()
// Setting the minutes
  lcd.clear();
    if (minupg==59)
      minupg=0;
      minupg=minupg+1;
    if (minupg==0)
      minupg=59;
      minupg=minupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Minutes:");
  lcd.setCursor(0,1);
  lcd.print(minupg,DEC);
  delay(200);
void DisplaySetYear()
// setting the year
  lcd.clear();
    yearupg=yearupg+1;
    yearupg=yearupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Year:");
  lcd.setCursor(0,1);
  lcd.print(yearupg,DEC);
  delay(200);
void DisplaySetMonth()
// Setting the month
  lcd.clear();
    if (monthupg==12)
      monthupg=1;
      monthupg=monthupg+1;
    if (monthupg==1)
      monthupg=12;
      monthupg=monthupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Month:");
  lcd.setCursor(0,1);
  lcd.print(monthupg,DEC);
  delay(200);
void DisplaySetDay()
// Setting the day
  lcd.clear();
    if (dayupg==31)
      dayupg=1;
      dayupg=dayupg+1;
    if (dayupg==1)
      dayupg=31;
      dayupg=dayupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Day:");
  lcd.setCursor(0,1);
  lcd.print(dayupg,DEC);
  delay(200);
void StoreAgg()
// Variable saving
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("SAVING IN");
  lcd.setCursor(0,1);
  lcd.print("PROGRESS");
  RTC.adjust(DateTime(yearupg,monthupg,dayupg,hourupg,minupg,0));
  delay(200);
void DisplaySetHourAll()// Setting the alarm minutes
  while(digitalRead(P1)==HIGH){
  lcd.clear();
    if(alarmHours==23)
      alarmHours=0;
      alarmHours=alarmHours+1;
    if(alarmHours==0)
      alarmHours=23;
      alarmHours=alarmHours-1;
  lcd.setCursor(0,0);
  lcd.print("Set HOUR Alarm:");
  lcd.setCursor(0,1);
  lcd.print(alarmHours,DEC);
  delay(200);
 delay(200);
void DisplaySetMinuteAll()// Setting the alarm minutes
  lcd.clear();
    if (alarmMinutes==59)
      alarmMinutes=0;
      alarmMinutes=alarmMinutes+1;
    if (alarmMinutes==0)
      alarmMinutes=59;
      alarmMinutes=alarmMinutes-1;
  lcd.setCursor(0,0);
  lcd.print("Set MIN. Alarm:");
  lcd.setCursor(0,1);
  lcd.print(alarmMinutes,DEC);
  delay(200);
 delay(200);
void printAllOn(){
   lcd.setCursor(0,2);
  lcd.print("Alarm: ");
  if (alarmHours <= 9)
    lcd.print("0");
  lcd.print(":");
  if (alarmMinutes <= 9)
    lcd.print("0");
void printAllOff() {
  lcd.setCursor(0, 2);
  lcd.print("Alarm: Off  ");
void Alarm(){
   if(digitalRead(P4)== LOW)
   setAll=setAll+1;
  if (setAll==0)
     printAllOff();
     noTone (buzzer);
     digitalWrite(LED,LOW);
  if (setAll==1)
     printAllOn();
     if ( now.hour() == alarmHours && now.minute() == alarmMinutes )
         RadioState = 0;
         lcd.noBacklight();
         digitalWrite(LED,HIGH);
         tone(buzzer,880,300); //play the note "A5" (LA5)
         delay (100);
         tone(buzzer,698,300); //play the note "F6" (FA6)
         lcd.backlight();
    else{
         noTone (buzzer);
  if (setAll==2)
     setAll=0;
    delay(20);
void Radio(){
if(digitalRead(MEMO)== LOW)
    memory = memory+1;
 if (memory == 0)
   frequencyUpdate();
  lcd.setCursor(0,3);
   lcd.print("FREQUENCY:    ");
   delay(20);
  if(digitalRead(P2)== LOW)
    count=0;
    while (digitalRead(P2)== LOW)
      count++;
      if(count > 0 && count <= 6)
        frequency += 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(200);
      else if (count > 6 && count <= 2)
        frequency += 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(80);
        frequency += 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(5);
    if (frequency == 108.5)
      frequency = 87.4;
   if(digitalRead(P3)== LOW)
     count = 0;
    while (digitalRead(P3)== LOW)
      count--;
     if(count < 0 && count >= -6)
        frequency -= 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(200);
      else if (count < -6 && count >= -12)
        frequency -= 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(80);
        frequency -= 0.1;
        frequencyUpdate();
        lcd.setCursor(0,3);
        delay(5);
    if (frequency == 87.5)
      frequency = 108.5;
if (memory == 1)
  frequencyUpdate();
   lcd.setCursor(0,3);
   lcd.print("RED FM :      ");
   delay(20);
  if (memory == 2)
   frequency = memory1;
   frequencyUpdate();
   lcd.setCursor(0,3);
   lcd.print("RADIO MIRCHI : ");
   delay(20);
  if (memory == 3)
   frequency = memory2;
   frequencyUpdate();
   lcd.setCursor(0,3);
   lcd.print("RADIO CITY :   ");
   delay(20);
  if (memory == 4)
   frequency = memory3;
   frequencyUpdate();
   lcd.setCursor(0,3);
   lcd.print("FM RAINBOW :  ");
   delay(20);
   if (memory == 5)
   frequency = memory4;
   frequencyUpdate();
   lcd.setCursor(0,3);
   lcd.print("AIR DTH :   ");
   delay(20);
   if (memory == 6)
   memory = 0;
   delay(20);
void frequencyUpdate() //this function changes the frequency of the station, is called by preset and frequency up/down conditions.
  frequency = constrain(frequency, 87.5, 108.5);
  lcd.setCursor(14,3);
  if (frequency < 99.90){
  lcd.print(" ");
  else{
void PrintRadioOff()
    lcd.setCursor(0,3);
   lcd.print("Radio: Off");
That's a big chunk of code to expect anyone to unravel.
My suggestion is firstly to uncomment the Serial.begin() and then put some debug prints in around the part where it's supposed to make a noise so that you can verify that the code's even going there in the first place.
Side note: why do you include the software serial library? As far as I can see it's not used.
