Need help with Stepper Motor code!
Hi guys, i want to adjust my motor’s speed with serial monitor. And i want to spin my motor one time whenever i change the speed with serial monitor. But whenever i write any number such as 3,4,7,9 my speed doesnt change and serial moniter gives me same sumbers(52,49,51). I think these numbers are Can you guys help me to get through this. Thank you in advance.
#include <Wire.h>
int BLACK=2;
int BROWN=4;
int ORANGE=6;
int YELLOW=8;
void setup(){
  pinMode(BLACK,OUTPUT);
  pinMode(BROWN,OUTPUT);
  pinMode(ORANGE,OUTPUT);
  pinMode(YELLOW,OUTPUT);
void step1(){
  digitalWrite(BLACK,LOW);
  digitalWrite(ORANGE,HIGH);
  digitalWrite(BROWN,HIGH);
  digitalWrite(YELLOW,LOW);
void step2(){
  digitalWrite(ORANGE,LOW);
  digitalWrite(YELLOW,HIGH);
void step3(){
  digitalWrite(BLACK,HIGH);
  digitalWrite(BROWN,LOW);
void step4(){
void Stop(){
void forward(int s){
  step1();
  delay(s);
  step2();
  delay(s);
  step3();
  delay(s);
  step4();
  delay(s);
void loop(){
if (Serial.available()) {
int c = Serial.read();
Serial.println(c);
forward(c);
Bciceksoy: if (Serial.available()) {
Try changing to this?
if (Serial.available() > 0) {
It will also print the same number because you are telling it to with Serial.println(c);
Still same. It gives me the keyboard number of key. When i press 1 key from keypad it gives 49, for 2 50 for 3 51.
OK, I'm no expert by any means, but instead of Serial.print(c); use Serial.write(c); will correct the 49,50,51 issue
I'm gonna have to get out my stepper but try this:
  int s = Serial.read();
  step1();
  delay(s);
  step2();
  delay(s);
  step3();
  delay(s);
  step4();
  delay(s);
void loop(){
Serial.write(s);
forward(s);
Guys thank you for your help but it is still same, the numbers are normal now but the speed is still same. :(
Bump
Why are you reading serial in loop() and again in forward() - it will give two completely different results.
Passing "s" to forward() is no use if you immediately ignore it and get a new value for s.
...R
Once you know that there is a byte to read, read the serial port, and store the data in a char, NOT an int.
Then, convert the char to a number by subtracting '0' form the digit you sent ('6' - '0' = 6).
Finally, ask your self if you can really tell the difference between a 1 millisecond pause between steps and a 9 millisecond pause.
When you are done pondering that, are you sending anything after the digit, like a carriage return and/or line feed?
Last, but by no means least, you aren't really expecting the Arduino to power a stepper motor, are you? Even the smallest ones require more power than the Arduino can provide.
