How would I code the syntax to fire the camera shutter every 14 minutes, just in case it's not triggered by lightning during that time period?
#define PIN_STATUS 13
#define PIN_IR_LED 12
#define FREQ 38400 // IR frequence
#define LIGHTNING_TRIGGER_ANALOG_PIN 0
#define TRIGGER_THRESHHOLD 50
//shutter sequence (on,off,on,off ... in microsecond)
unsigned long sequence[] = {2000,27830,390,1580,410,3580,400,63200,2000,27830,390,1580,410,3580,400,0};
int seq_l;
int lightningVal;
//oscd is a delay in microsecond used at each oscillation.
int oscd;
void oscillate(int pin, unsigned long n, int shine){
int ir_status=0;
while(n>0){
n--;
delayMicroseconds(oscd);
ir_status = !ir_status;
digitalWrite(pin, ir_status && shine);
void snap(){
int i;
digitalWrite(PIN_STATUS, 1);
for(i=0;i<seq_l;i++){
oscillate(PIN_IR_LED, sequence[i], i%2==0);
digitalWrite(PIN_STATUS, 0);
lightningVal = analogRead(LIGHTNING_TRIGGER_ANALOG_PIN);
int min=1, max=100, i;
int last_oscd=0;
unsigned long before, intervalle;
oscd=max;
seq_l = sizeof(sequence)/sizeof(unsigned long);
pinMode(PIN_STATUS, OUTPUT);
pinMode(PIN_IR_LED, OUTPUT);
//this "while" will process the best "oscd"
Serial.println("Ready");
while(last_oscd!=oscd){
last_oscd=oscd;
oscd=(min+max)>>1;
before=millis();
oscillate(PIN_STATUS, FREQ, 1);
intervalle=millis()-before;
if(intervalle >= 1000) max=oscd;
else min=oscd;
Serial.print(intervalle);
Serial.print(" : ");
Serial.print(min);
Serial.print("<->");
Serial.println(max);
Serial.print("oscd: ");
Serial.println(oscd);
//rewrite the sequence array, we replace all values in microsecond by the number of oscillation
Serial.print(sequence[i]);
Serial.print("->");
sequence[i] = (sequence[i] * FREQ) / (intervalle * 1000);
Serial.println(sequence[i]);
int cmd;
int newLightningVal = analogRead(LIGHTNING_TRIGGER_ANALOG_PIN);
Serial.println(lightningVal, DEC);
if (abs(newLightningVal - lightningVal) > TRIGGER_THRESHHOLD)
snap();
Serial.println("Shutter triggered");
//delay(200);
lightningVal = newLightningVal;
thank you.....
Jim
