Need help with Tab's
Hello, I am very new here and very new trying to learn Arduino. I am wondering if there is a way that I can Tab between both readings just for the purpose of the serial monitor. I apologize if I did anything wrong on this post. if its not practical to do for the serial monitor, then its not a huge deal. I am also going to probably need some help making a simple menu as well, but I'm going to go back and give some honest effort before I do. I am trying to use the LCD keypad. Thanks a bunch!!
#include <Adafruit_Keypad.h>
#include <Adafruit_Keypad_Ringbuffer.h>
#include <SD.h>
#include <SPI.h>
File myFile;                                         // Using Uno
int pinCS = 10; // Pin 10 on Arduino Uno
const int tpsRead = analogRead(A0);                  // Pins that will not change
const int mapRead = analogRead(A2);
  pinMode(pinCS, OUTPUT);
  // SD Card Initialization
  if (SD.begin())
    Serial.println("   SD card is ready to use.");
  } else
    Serial.println("   Verify SC card is fully inserted");
    return;
void loop() {                                    //Operational code that runs continously
  int tpsRead;
  float throttle;                                // Throttle position first attempt to scale
   throttle = tpsRead  * (5.0 / 1023);
          Serial.println(throttle    );
          Serial.print("Throttle  ");
   int mapRead;                                  // MAP sensor first attempt to scale
    float pressure;
      pressure = mapRead * (5.0 / 1023);
          Serial.println(pressure  );
          Serial.print("Pressure  "  );
Hi @mrturbo. I don't understand what you mean by "a way that I can Tab between both readings". Would you mind providing a more detailed description of what you are hoping to achieve?
@mrturbo
You can use the \t switch at the end of serialprint.
See serialprint function in arduino website.
Tabs may not be implemented in the simplified serial terminal offered by the IDE. They will certainly work in a real terminal emulation application, though.
Thank you for your response. I wil try that. Sorry about the lack of clarity. I meant the readings of the tps and map sensors. so that on serial screen, it would look something like this:
map 12.4 tps 30 as oppose to : map
12.4
scroll scroll. tps
30
scroll
Tabs using \t work fine in the Arduino IDE's Serial Monitor.
