Need help with telegram code (Arduino mega+esp8266 -ESP-01))
This is code for my arduino , but when it comes to send telegram message serial monitor show error:
WiFiEsp] Connecting to api.telegram.org
[WiFiEsp] Data packet send error (2)
[WiFiEsp] Failed to write to socket 3
[WiFiEsp] Disconnecting 3
#include <WiFiEsp.h>
#include <WiFiEspServer.h>
#include <DHT.h>
#include <UniversalTelegramBot.h>
#define DHTPIN 2        // DHT11 data pin
#define DHTTYPE DHT11   // DHT11 sensor type
#define MQ2PIN A0       // MQ2 sensor analog pin
#define LED_PIN 3
// Telegram Bot credentials
#define TELEGRAM_BOT_TOKEN "xxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
#define CHAT_ID "xxxxxxxxxxxxxxxxx"
char ssid[] = "Internet";
char pass[] = "Password";
int status = WL_IDLE_STATUS;
WiFiEspServer server(80);
WiFiEspClient client;
int threshold = 150; // Adjust threshold as needed
bool alert = false;
DHT dht(DHTPIN, DHTTYPE);
UniversalTelegramBot bot(TELEGRAM_BOT_TOKEN, client);
  Serial1.begin(115200);
  pinMode(MQ2PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
  dht.begin();
  WiFi.init(&Serial1);
  // Check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while (true);
  // Attempt to connect to WiFi network
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(5000);
  // Start the web server
  server.begin();
  static unsigned long previousMillis = 0;
  // Refresh webpage every 5 seconds
  if (currentMillis - previousMillis >= 7000) {
    WiFiEspClient client = server.available();
    if (client) {
      Serial.println("New client");
      String response = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
      response += "<html><body>";
      response += "<meta http-equiv='refresh' content='7'>";
      response += "<h1>DHT11 and MQ2 Sensor Readings</h1>";
      response += "<p>Temperature: ";
      response += String(readTemperature());
      response += "°C</p>";
      response += "<p>Humidity: ";
      response += String(readHumidity());
      response += "%</p>";
      response += "<p>Smoke Value: ";
      int gasReading = readGas();
      response += String(gasReading);
      response += "</p>";
      if (gasReading > threshold) {
    response +=("<p style='color:red'>Gas Alert! Ventilate immediately!</p>");
    digitalWrite(LED_PIN, HIGH); // Turn on LED if gas exceeds threshold
    // Send Telegram message
    sendTelegramMessage("Gas Alert! Ventilate immediately!");
    response += "<p>Telegram sent";
    Serial.println("Telegram sent");
    digitalWrite(LED_PIN, LOW); // Turn off LED if gas is below threshold
      response += "</body></html>";
      client.print(response);
      delay(1);
      client.stop(); // Close the connection after sending the response
      Serial.println("Client disconnected");
float readTemperature() {
  return dht.readTemperature();
float readHumidity() {
  return dht.readHumidity();
int readGas() {
  return analogRead(MQ2PIN);
void sendTelegramMessage(String message) {
  bot.sendMessage(CHAT_ID, message, "");
does it support unsecure connection?
Here are some info regarding the data packet error (2): Data packet send error (2) & Data packet send error (1) · Issue #111 · bportaluri/WiFiEsp · GitHub
it think it does
put delay but it was not helpful
if the AT firmware is 1.7 or you can update it, you can use my WiFiEspAT library, which doesn't have these timeout issues
