Need help with upload error
Hello All,
While running the Blink program on the sketch, I am having the following error on upload:
Found programmer: Id = "B¡K"; type =
Software Version = . ; Hardware Version = .
avrdude: error: buffered memory access not supported. maybe it
isn't
a butterfly/AVR109 but a AVR910 device?
I am using an Arduino Micro powered through the USB port with no hardware connected to any of the pins.
The arduino is connected to a Samsung QX series laptop updated to Windows 8 (Which I am starting to hate).
I installed the driver as a Compaq Modem set at 9600 baud.
The Arduino Micro is selected.
When I run the serial monitor the serial data window pops and data appears in the form of the word TESTATA followed by a
carriage return and line feed. This is repeated in an endless loop for as long as the pop up window is open.
When I upload I can see the Arduino resetting automatically and the TX Led blinks a few times. Then the upload times out.
Anyone seen this error before? Any help will be appreciated.
Hugo
Problem Solved....
Initially since I am working with Windows 8 the driver did not download. Since the driver is almost identical to the compaq modem, I loaded it as a modem and it appeared to comminicate well. WHile it may work with other Arduino boards it does not work with the Arduino Micro. Later I found the proper way to load the driver in Windows 8.
Lessons Learned?
1- Not all Arduinos are built the same way
2- RTFM
Hugo
There is youtube vodeo for that.when i also used to have the same problem dwnloading arduino ide and later came to know about the similarity with compaq modem.
