Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P"
In function 'void scanJoystick()':
warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
while (millis() < timestamp + snakeSpeed) {
In lambda function:
for (int d = 0; d < sizeof(snakeMessage[0]) - 7; d++) {
: In lambda function:
: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int d = 0; d < sizeof(gameOverMessage[0]) - 7; d++) {
for (int d = 0; d < sizeof(scoreMessage[0]) + 2 * sizeof(digits[0][0]); d++) {
if (d <= sizeof(scoreMessage[0]) - 8) {
Sketch uses 10426 bytes (33%) of program storage space. Maximum is 30720 bytes.
Global variables use 424 bytes (20%) of dynamic memory, leaving 1624 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
The error messages posted are warnings that can be ignored. The problem is in the upload step.
Enable this option (also check the "upload" box) and post the result:
