Need help with using millis() with lcd
Hi I am trying to use the function millis() with my lcd. What I want my code to do is display two sentences on the same line with a 3000 millis delay for each. However, I can not use the delay() function as I also have to use the keypad. With my code now when the cursor is at (0,2) the sentences keep overlapping and changing very quickly. Any suggestions on what I can add to my code to have that 3000 millis difference? Thank you.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <Keypad.h>
const long interval = 3000;
unsigned long currentMillis = 3000;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3', 'A'},
  {'4','5','6', 'B'},
  {'7','8','9', 'C'},
  {'*','0','#', 'D'}
byte rowPins[ROWS] = { 9,8,7,6 };
byte colPins[COLS] = { 5,4,3,2 };
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
 long Num1,Num2,Number;
 char key,action;
 boolean result = false;
  lcd.init();
  lcd.begin(20,4);
  lcd.backlight();
  lcd.setCursor(0,2);
  lcd.print("Dry Bulb Temp ( C): ");
  lcd.setCursor(15,2);
  lcd.print((char)223);
  lcd.setCursor(1,3);
  lcd.print("10");
  millis();
  lcd.print(" ");
  lcd.setCursor(0,2);
  lcd.print("Wet Bulb Temp ( C): ");
  lcd.setCursor(1,3);
  lcd.print("30");
  millis();
  lcd.print(" ");
  lcd.setCursor(0, 0);
  lcd.print("Enter Duct Size(in): ");
key = kpd.getKey();
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
void DetectButtons()
    lcd.clear();
    if (key=='C')
    {Serial.println ("Clear"); Number=Num1=Num2=0; result=false;}
    if (key == '1')
    {Serial.println ("Button 1");
    if (Number==0)
    Number=1;
    Number = (Number*10) + 1;
     if (key == '4')
    {Serial.println ("Button 4");
    if (Number==0)
    Number=4;
    Number = (Number*10) + 4;
     if (key == '7')
    {Serial.println ("Button 7");
    if (Number==0)
    Number=7;
    Number = (Number*10) + 7;
    if (key == '0')
    {Serial.println ("Button 0");
    if (Number==0)
    Number=0;
    Number = (Number*10) + 0;
     if (key == '2')
    {Serial.println ("Button 2");
     if (Number==0)
    Number=2;
    Number = (Number*10) + 2;
     if (key == '5')
    {Serial.println ("Button 5");
     if (Number==0)
    Number=5;
    Number = (Number*10) + 5;
     if (key == '8')
    {Serial.println ("Button 8");
     if (Number==0)
    Number=8;
    Number = (Number*10) + 8;
    if (key == '#')
    {Serial.println ("Equal");
    Num2=Number;
    result = true;
     if (key == '3')
    {Serial.println ("Button 3");
     if (Number==0)
    Number=3;
    Number = (Number*10) + 3;
     if (key == '6')
    {Serial.println ("Button 6");
    if (Number==0)
    Number=6;
    Number = (Number*10) + 6;
     if (key == '9')
    {Serial.println ("Button 9");
    if (Number==0)
    Number=9;
    Number = (Number*10) + 9;
      if (key == '*')
    Num1 = Number;
    Number =0;
    if (key == '*')
    {action = '*';}
    delay(100);
void CalculateResult()
  if (action=='*')
    Number = Num1*Num2;
void DisplayResult()
  lcd.setCursor(2, 1);
  lcd.print(Num1); lcd.print(action); lcd.print(Num2);
  if (result==true)
  {lcd.print(" Area = "); lcd.print(Number/12); lcd.setCursor(17,1); lcd.print("ft");}
Hello zxames12
Take a view at the BlinkWithOutDelay exmple from the IDE, based on this example you are able to design and build your own timers for your project.
Thank you for your help. I tried this but I am still getting the same result where the sentences are changing really fast. I would like the first sentence to change to the second one after 3000 millis. Is there anything else I can try?
#include <Wire.h>
#include <Keypad.h>
unsigned long previousMillis = 0;
  {'1','2','3', 'A'},
  {'4','5','6', 'B'},
  {'7','8','9', 'C'},
  {'*','0','#', 'D'}
 char key,action;
  lcd.init();
  lcd.begin(20,4);
  lcd.backlight();
  if (currentMillis - previousMillis >= interval) {
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("10");
  millis();
  lcd.print(" ");
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("30");
  millis();
  lcd.print(" ");
key = kpd.getKey();
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
    lcd.clear();
    if (key=='C')
    if (key == '1')
    if (Number==0)
    Number=1;
     if (key == '4')
    if (Number==0)
    Number=4;
     if (key == '7')
    if (Number==0)
    Number=7;
    if (key == '0')
    if (Number==0)
    Number=0;
     if (key == '2')
     if (Number==0)
    Number=2;
     if (key == '5')
     if (Number==0)
    Number=5;
     if (key == '8')
     if (Number==0)
    Number=8;
    if (key == '#')
    Num2=Number;
    result = true;
     if (key == '3')
     if (Number==0)
    Number=3;
     if (key == '6')
    if (Number==0)
    Number=6;
     if (key == '9')
    if (Number==0)
    Number=9;
      if (key == '*')
    Num1 = Number;
    Number =0;
    if (key == '*')
    {action = '*';}
    delay(100);
  if (action=='*')
    Number = Num1*Num2;
  if (result==true)
Hello zxames12
Check your code again.
You have coded a timer but the timing function migth not be implemented correct.
Sorry can you show this on my code because I am having trouble understanding exactly what is wrong.
Tell us what you think is happening here ?
if the currentmillis - previousmillis is greater than or equal to the interval then they both equal each other?
As it is, these lines of code don’t do anything useful.
If, on the other hand, you add some code between the braces, then that code would run every 3 seconds.
example:
interval = 3000;
    //restart this TIMER
    digitalWrite( myLED, !digitalRead(myLED);  // toggle myLED every 3 seconds
Oh ok so if I were to add my lcd code between the braces then it should print every 3 seconds?
Give it a try.
:wink:
Thank you! I am getting closer to what I am wanting however, with this new change the lcd.print("Wet Bulb Temp ( C): "); line stays on the lcd and the lcd.print("Dry Bulb Temp ( C): "); line is going so fast I can't see it. I tried chaning the previousMillis = 0; and interval = 1000; values to a higher millis but the results are the same.
#include <Wire.h>
#include <Keypad.h>
const long interval = 1000;
  {'1','2','3', 'A'},
  {'4','5','6', 'B'},
  {'7','8','9', 'C'},
  {'*','0','#', 'D'}
 char key,action;
  lcd.init();
  lcd.begin(20,4);
  lcd.backlight();
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("10");
  lcd.print(" ");
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("30");
  lcd.print(" ");
key = kpd.getKey();
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
    lcd.clear();
    if (key=='C')
    if (key == '1')
    if (Number==0)
    Number=1;
     if (key == '4')
    if (Number==0)
    Number=4;
     if (key == '7')
    if (Number==0)
    Number=7;
    if (key == '0')
    if (Number==0)
    Number=0;
     if (key == '2')
     if (Number==0)
    Number=2;
     if (key == '5')
     if (Number==0)
    Number=5;
     if (key == '8')
     if (Number==0)
    Number=8;
    if (key == '#')
    Num2=Number;
    result = true;
     if (key == '3')
     if (Number==0)
    Number=3;
     if (key == '6')
    if (Number==0)
    Number=6;
     if (key == '9')
    if (Number==0)
    Number=9;
      if (key == '*')
    Num1 = Number;
    Number =0;
    if (key == '*')
    {action = '*';}
    delay(100);
  if (action=='*')
    Number = Num1*Num2;
  if (result==true)
Since you are reusing the same LCD locations You need to come up with a design that switches between displays alternately.
Example:
Let’s say you have a variable called oddFlag
byte oddFlag = 0;
When oddFlag is == to 0 you print to the LCD Wet Bulb Temp
When oddFlag is == to 1 you print to the LCD Dry Bulb Temp
In your 3 second TIMER oddFlag needs to be changed between 0 and 1.
Therefore, the first 3 seconds you get Wet Bulb and then the next 3 seconds you get Dry Bulb etc.
Thank you that helped. How would i change oddFlag from 0 to 1 without manually typing it in?
#include <Wire.h>
#include <Keypad.h>
const long interval = 100;
byte oddFlag = 0;
  {'1','2','3', 'A'},
  {'4','5','6', 'B'},
  {'7','8','9', 'C'},
  {'*','0','#', 'D'}
 char key,action;
  lcd.init();
  lcd.begin(20,4);
  lcd.backlight();
  if (oddFlag==0)
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("10");
  lcd.print(" ");
  if (oddFlag==1)
  lcd.setCursor(0,2);
  lcd.setCursor(1,3);
  lcd.print("20");
  lcd.print(" ");
You need something like this (to be tested):
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#include <Keypad.h>
byte oddFlag    = 0;
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = { 9, 8, 7, 6 };
byte colPins[COLS] = { 5, 4, 3, 2 };
long Num1, Num2, Number;
char key, action;
  lcd.init();
  lcd.begin(20, 4);
  lcd.backlight();
} //END of   setup()
    if (oddFlag == 0)
      lcd.setCursor(0, 2);
      lcd.setCursor(15, 2);
      lcd.setCursor(1, 3);
      lcd.print("10");
      lcd.print(" ");
      lcd.print("20");
      lcd.print(" ");
    //toggle the Flag
    oddFlag = 1 - oddFlag;
} //END of   loop()
That worked!! Thank you so much!
You need to make interval = 3000; //3 seconds
Do you know why it works ?
Yes i changed it to 3000. Thank you again!
yes I had to make it an if else statement to have the print change.
And you have to:
    //toggle the Flag
When it is 0, it changes to 1 (Odd)
When it is 1, it changes to 0 (Even)
