I built a 7-segment display, hooked it up and all characters work, but I am having a little trouble. My display has two 7-segments side by side, so I can display from 0 to 99. I want to be able to use a pot and map the value from 0 to 99 two show the val on the display. My question is, if my pot val is 48, is there a way that i can split the number into two numbers which would be 4 and 8 so that that i can just assign the 4 to the first 7-segment and 8 to the seconed.
I cant seem to get it going, I just need to be able to maybe multiplex the two displays? any other sugestions on how to do this?
yes, yes, yes, no. I still need to be able to do that part.
To be honest Right now all i did was make a code to drive the first decimal place from 0 to 9 using the pot and I got it going very easily. this is the code I used.
int a1 = 2;
int b1 = 13;
int c1 = 10;
int d1 = 6;
int e1 = 5;
int f1 = 3;
int g1 = 4;
int a2 = 17;
int b2 = 14;
int c2 = 16;
int d2 = 15;
int e2 = 12;
int f2 = 8;
int g2 = 9;
int t = 1000;
int pot;
void setup(){
pinMode(a1, OUTPUT);
pinMode(b1, OUTPUT);
pinMode(c1, OUTPUT);
pinMode(d1, OUTPUT);
pinMode(e1, OUTPUT);
pinMode(f1, OUTPUT);
pinMode(g1, OUTPUT);
pinMode(a2, OUTPUT);
pinMode(b2, OUTPUT);
pinMode(c2, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(e2, OUTPUT);
pinMode(f2, OUTPUT);
pinMode(g2, OUTPUT);
void loop(){
pot = analogRead(4);
pot = map(pot, 0, 1023, 0, 9);
Serial.println(pot, DEC);
if(pot == 0){
bzero();
if(pot == 1){
bone();
if(pot == 2){
btwo();
if(pot == 3){
bthree();
if(pot == 4){
bfour();
if(pot == 5){
bfive();
if(pot == 6){
bsix();
if(pot == 7){
bseven();
if(pot == 8){
beight();
if(pot == 9){
bnine();
void bzero(){
digitalWrite(a2, HIGH);
digitalWrite(b2, HIGH);
digitalWrite(c2, HIGH);
digitalWrite(d2, HIGH);
digitalWrite(e2, HIGH);
digitalWrite(f2, HIGH);
digitalWrite(g2, LOW);
void bone(){
digitalWrite(a2, LOW);
digitalWrite(d2, LOW);
digitalWrite(e2, LOW);
digitalWrite(f2, LOW);
void btwo(){
digitalWrite(c2, LOW);
digitalWrite(g2, HIGH);
void bthree(){
void bfour(){
void bfive(){
digitalWrite(b2, LOW);
void bsix(){
void bseven(){
void beight(){
void bnine(){
void alloff(){
In the code a1 is the first display and it drives the top middle led just as a is on all 7-segments and when you get to a2 its the second display top middle and so on.
Ill admit the code is a mess but it works. now that Ive done this part I need to use both of the displays, I dont know how to do this. Can you give me an example?
It is a very long winded naive way of writing code. However take this bit:-
and change it to:-
potRaw = map(pot, 0, 1023, 0, 9);
pot = potRaw % 10; // modulo operator
... all your code driving the first digit
then do
pot = potRaw / 10;
... all your code again but now driving the second digit
That will do it. Then learn how to write code properly using arrays.
then do
pot = potRaw / 10;
potRaw will be a one digit number...
Probably want to map to 0, 99 to get a two digit number.
Yes well spotted I didn't see the map function. Just need to change it to:-
potRaw = map(pot, 0, 1023, 0, 99);
Rewrote the code to make it do only the first digit, but had a few problems.
This is the new code*
int a1 = 2;
int b1 = 13;
int c1 = 10;
int d1 = 6;
int e1 = 5;
int f1 = 3;
int g1 = 4;
int a2 = 17;
int b2 = 14;
int c2 = 16;
int d2 = 15;
int e2 = 12;
int f2 = 8;
int g2 = 9;
int t = 1000;
byte potRaw;
int pot;
void setup(){
void loop(){
potRaw = analogRead(4);
potRaw = map(potRaw, 0, 1023, 0, 99);
pot = potRaw % 10;
if(pot == 0){
bzero();
if(pot == 1){
bone();
if(pot == 2){
btwo();
if(pot == 3){
bthree();
if(pot == 4){
bfour();
if(pot == 5){
bfive();
if(pot == 6){
bsix();
if(pot == 7){
bseven();
if(pot == 8){
beight();
if(pot == 9){
bnine();
if(pot == 10){
bten();
pot = potRaw / 10;
void bzero(){
digitalWrite(a1, HIGH);
digitalWrite(b1, HIGH);
digitalWrite(c1, HIGH);
digitalWrite(d1, HIGH);
digitalWrite(e1, HIGH);
digitalWrite(f1, HIGH);
digitalWrite(g1, LOW);
void bone(){
void btwo(){
void bthree(){
void bfour(){
void bfive(){
void bsix(){
void bseven(){
void beight(){
void bnine(){
void bten(){
digitalWrite(a1, LOW);
digitalWrite(d1, LOW);
digitalWrite(e1, LOW);
digitalWrite(f1, LOW);
void alloff(){
This code counts from 0 to 9, 9 times on the first digit but after the last nine it keeps counting up to the next 4 it doesnt stop after the 9th nine.
http://s1013.photobucket.com/albums/af256/sdgsdfgsdf_2010/?action=view¤t=IMG_0522.flv
Yes that is what you wrote. You didn't do what I said.
You just did :-
pot = potRaw / 10;
at the end of the loop and then you repeat writing the first digit again. You should follow the pot = potRaw / 10; by all the code written again but addressing the most significant digit display.
As I said it is not the right way to do it but it will work.
