Need LEDs to reset with a timer
I've made a row of LEDs pins 2-7, I've gotten them to all turn on and then reset back and forth. But it seems to reset too fast, the second last LED turns on only for a fraction of a second, and the last doesn't seem to turn on at all.
In my mind I'm thinking.
If led 7 is on for 100ms, led = 2
To allow for the program to not reset so quick, how would I do this? And is there a better way?
unsigned long previousTime = 0;
int led = 2;
long interval = 500;
for (int x = 2; x < 8; x++) {
pinMode(x, OUTPUT);
unsigned long currentTime = millis();
if (currentTime - previousTime > interval) {
previousTime = currentTime;
digitalWrite(led, HIGH);
led++;
if (led == 7) {
digitalWrite(x, LOW);
led = 2;
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
  led++;
  if (led == 8)
   led = 2;
for illustration, not tested.
int led = 2;
int LEDcount = 6;
int arrayLEDpins[6] = {2, 3, 4, 5, 6, 7};
bool Tick = true;
  for (int x = 0; x >= LEDcount; x++)
    pinMode( arrayLEDpins[x], OUTPUT );
int currentLED = 0;
  if ( currentTime - previousTime >= interval )
    if ( Tick )
      digitalWrite(arrayLEDpins[currentLED], HIGH);
      currentLED++;
      previousTime = millis();
      if ( currentLED >= LEDcount )
        Tick = !Tick;
      digitalWrite(arrayLEDpins[currentLED], LOW);
      currentLED--;
      if ( currentLED == 0 )
        Tick = !Tick;
This should work...
unsigned long interval = 500;
int led = 2;
    pinMode(x, OUTPUT);
    if (led == 8)
      led = 2;
      digitalWrite(led++, HIGH);
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
Thank you, I didn't know < meant less then, instead I ended up using <=7. Feel a little silly
