Hi all, I tried the search function but wasn't sure exactly what to look for.
I'm working on a project that requires more output than 5V can provide. I'm running an OLED, DFRobot Huskylens, a handful of FETs, switches, and the like. I thought about using an external 5V regulator, but am having trouble with some grounding issues. Any advice?
Actually, it suggests that the poster has discovered either by reading or by trial and error, that the "5V" pin on an Arduino (with certain exceptions) is not in any way usable as a source of 5 V.
So you need a regulated 5 V power supply - a USB "phone charger" is often the easiest source - connected to supply the "5V" pin and ground as well as to all the other 5 V devices.
It is advised for a UNO to disconnect the "5V" pin (but of course, not the ground) whilst connected to a PC.
All grounds connect together - what other problems might you have?
