Need optimisation in Serial message
I have a simple problem, i need to send 512 values via Serial TX, all values are between 0 and 255.
How can i encode value in one octet send it via TX recieve it via RX and decode it ?
If the values are all between 0 and 255 then they are each one byte which is the same unit that Serial works with.
What do you mean by "one octet" ?
you simple don't need encode them.
  • do you want to send them as a string of bytes?
  • how do you recognize the first byte or the end of transmission?
have you considered Serial.write()?
