Need part advice for external power
Hi, i'm triyng to run 12 Servos (each require 5V and 550mA) and an Arduino UNO with external power coming from a Lithium Polymere Akku.
My question is wich Akku and step-down module i need to power all of this. It would be best if the Parts were as small and light as possible.
i hope someone can reccomend me the required parts.
  1. There are are like hundreds of parts that can work. Do you have more requirements?
  2. Do all servo's need to run at the same time?
  3. Are you sure about the 550mA? I can tell you, that is very light even for a small servo :wink:
  4. I think I would go for a LiPo / servo combo which does not need a converter to keep it simple
Does Akku mean battery?
Yeah, quite some countries call rechargeable batteries akku/accu :slight_smile:
septillion:
  1. i'm building a very simple walking robot, so except weight not really. And i guess that common liPos arent that heavy
  2. they need to run at the same time
  3. thats what the Datasheet said
  4. i'll look into that, thanks
And otherwise, I think I would just grab 1A or 2A step down converters from China and just give every servo it's own converter :slight_smile:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html.
Can you post links to data/specs of your servo and battery?
Important question; What is the specs on the battery, Voltage, Capacity?
Thanks.. Tom.. :slight_smile:
PS. I'm surprised this was not one of the first questions asked?
TomGeorge:
That was because he did gave a figure for the servo current (true or not) and I assumed he already did the battery calculations (current capacity and energy capacity) because he only asked about the conversion.
TomGeorge:
I still need a battery. Is there anything i have to look out for?
Or could you please recommend a battery that works for me?
Thanks!
septillion:
Will it work if i get 6 of these:
https://www.amazon.de/gp/product/B06XYDNM77/ref=s9_acsd_hps_bw_c_x_1_w
and hook up 2 servos each?
Probably :slight_smile: If the real stall current is indeed 550mA. Because those will need a heat sink above +-1A.
