NEED PROGRAMMING HELP FOR WS2812B
Recently i completed : 2 PIR motion sensor based Arduino Uno Staircase Lighting(WS2812B L.E.D Strip) project with he help of this forum.
The sketch which i found online worked as expected but since i have very little knowledge of coding,now i am stuck at desired color change part.At present its producing white color with fade out effect but when i try to change the color to any other color,the fade out effect doesn’t work.
Can anyone give me guidance for this?How can i change the color with fade out effect?
The sketch which i am using is as follow:
#define PIN 6                    // Digital output to LED
// Set up Variables
int NUM_STRIPS = 16;             // number of strips/steps
int PIXELS_PER_STRIP = 6;        // number of pixels in each strip
int MAX_BRIGHTNESS = 250;        // LED brightness (0 - 255)
int TOP_SENSOR_PIN = 10;         // PIR at the top of the stairs
int BOTTOM_SENSOR_PIN = 12;      // PIR at the bottom of the stairs
unsigned long timeOut=600000; // timestamp to remember when the PIR was triggered.
int downUp = 0;              // variable to rememer the direction of travel up or down the stairs
int alarmValueTop = LOW;    // Variable to hold the PIR status
int alarmValueBottom = LOW; // Variable to hold the PIR status
int ledPin = 13;           // LED on the arduino board flashes when PIR activated
// total number of pixels
int NUM_LEDS = NUM_STRIPS * PIXELS_PER_STRIP;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  strip.begin();
  strip.show();             // Initialize all pixels to 'off'
  pinMode(ledPin, OUTPUT);  // initilise the onboard pin 13 LED as an indicator
  // Constantly poll the PIR at the top of the stairs
  alarmValueTop = digitalRead(TOP_SENSOR_PIN);
  // Constantly poll the PIR at the bottom of the stairs
  alarmValueBottom = digitalRead(BOTTOM_SENSOR_PIN);
  if (alarmValueTop == HIGH)  {
    timeOut=millis();  // Timestamp when the PIR is triggered.  The LED cycle wil then start.
    downUp = 1;
    //clearStrip();
    topdown();         // lights up the strip from top down
  if (alarmValueBottom == HIGH)  {
    downUp = 2;
    //clearStrip();
    bottomup();         // lights up the strip from bottom up
  delay(100);
  if (timeOut+20000 < millis() && timeOut+30000 < millis() && alarmValueTop != HIGH && alarmValueBottom != HIGH) {    //switch off LED's in the direction of travel.
     if (downUp == 1) {
        darkenDOWN(); // Off
     if (downUp == 2)  {
      darkenUP();   // Off
    downUp = 0;
void topdown() {
  digitalWrite(ledPin,HIGH);
  delay(200);
  digitalWrite(ledPin,LOW);
  brightenDOWN();
void bottomup() {
  delay(200);
  brightenUP();
void brightenDOWN(){
  uint16_t a;
  for (a = 0; a < NUM_STRIPS; a++) {
    int start = PIXELS_PER_STRIP * a;
    brighten(start, 1);
void brightenUP(){
  uint16_t a;
  for (a = NUM_STRIPS; a > 0; a--) {
    int start = PIXELS_PER_STRIP * (a-1);
    brighten(start, 1);
// 0 to 255
void brighten(uint16_t ledNum, uint16_t wait) {
  uint16_t c, i;
  for (c = 0; c < MAX_BRIGHTNESS; c++) {
    for (i = ledNum; i < (ledNum + PIXELS_PER_STRIP); i++) {
      strip.setPixelColor(i, c, c, c);
    c = c+3;
    strip.show();
    delay(wait);
void darkenDOWN(){
  uint16_t b;
  for (b = 0; b < NUM_STRIPS; b++) {
    int start = PIXELS_PER_STRIP * b;
    darken(start, 1);
void darkenUP(){
  uint16_t b;
  for (b = NUM_STRIPS; b > 0; b--) {
    int start = PIXELS_PER_STRIP * (b-1);
    darken(start, 1);
// 255 to 0
void darken(uint16_t ledNum, uint16_t wait) {
  uint16_t c, i;
  for (c = MAX_BRIGHTNESS; c > 0; c--) {
    c--;
    strip.show();
    //delay(wait);
  // trun off the strip completely
    strip.setPixelColor(i, (0,0,0));
  strip.show();
LED-Stair-Lighting.pdf (507 KB)
LED Stair Lights Arduino Code (5).ino (3.91 KB)
