I need analogue values for the following gases, for a project. Please recommend some sensors that can be used for the same and compatible with arduino.
- Hydrocarbons
- CO
- NOX
4 CO2 - Smoke
Thank You.
Thank You.
You could buy an industrial calibrated measuring apparatus for thousands of dollars.
For the Arduino the MQ sensors are often used. But they can not detect a certain gas, they detect a number of gasses. Therefor they can be used for air quality, but not to determine amount of a certain gas.
Another major disadvantage of the MQ sensors is that they require a certain amount of current for the heater and the sensor gets hot.
http://playground.arduino.cc/Main/MQGasSensors
If you buy a few of those sensor on Ebay for a few dollars, you can check for yourself how they behave.
If you want accurate values for the different gasses, it's gonna cost a lot of money. If you want to have a number for the air quality, the MQ sensors are cheap, not accurate at all, but very sensitive.
