#include <WiFi.h>
WiFiClient client;
#include <Wire.h>
#include <SDL_Arduino_INA3221.h>
SDL_Arduino_INA3221 ina3221;
LiquidCrystal_I2C lcd1(0x27, 20, 4);
//LiquidCrystal_I2C lcd(0x25, 20, 4);
const char* ssid = "722027";
const char* password = "240833348";
const char* host = "tolentino-solarpanel.000webhostapp.com";
const char* url = "/index.php";
// INA3221
float busvoltage1 = 0;
float val2 = 0; // LEADACID
float busvoltage2 = 0;
float val5 = 0; // LIPO
int vin1 = 0; //Procent % Lead Acid Battery //int
int vin2 = 0; //Procent % Lipo Battery // int
// the three channels of the INA3221
#define LEADACID_BATTERY_CHANNEL 1 // Leadacid Battery
#define LIPO_BATTERY_CHANNEL 2 // Lipo4 Battery
#define ONBOARD_LED 2
const int buttonPin23 = 23; // Manually Lipo4 zu Lead Acid aktivieren K1
const int buttonPin18 = 18; // not used
int RelayControl33 = 33; // LED RED - Buzzer
const int buttonPin19 = 19; // Manual Arduino RESET
const int buttonPin16 = 16; // not used
const int buttonPin12 = 12; // not used
int RelayControl13 = 13; // K1 Lipo4 to Leadacid ON/OFF
int RelayControl27 = 27; // K2 not used
int RelayControl25 = 25; // K3 Fridge ON/OFF 230V normal Power
int RelayControl26 = 26; // K4 Fridge ON/OFF Inverter
// Reset Function Arduino by AH by 998
void (*resetFunc)(void) = 0; // declare reset fuction at address 0
// SMILY
byte a[8] = { //SMILE
B00000,
B00000,
B01010,
B00000,
B10001,
B01110,
B00000,
B00000
byte b[8] = { //unhappy
B00000,
B01010,
B00000,
B00000,
B01110,
B10001,
B00000,
B00000
byte c[8] = { // !
B00000,
B00100,
B00100,
B00100,
B00100,
B00100,
B00000,
B00100
//FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
// Functions
//FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
void connectWiFi() {
WiFi.begin(ssid, password);
int counter = 0;
counter++;
if (counter >= 20) {
lcd1.setCursor(0, 2);
lcd1.print(" ");
lcd1.print("Wifi Restart");
delay(10000);
ESP.restart();
counter = 0;
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Wire.begin();
connectWiFi();
lcd1.init();
lcd1.init(); // Start lcd1 Display(Top one)
lcd1.backlight();
lcd1.createChar(0, a); // SMILY
lcd1.createChar(1, b); // UNHAPPY
lcd1.createChar(2, c); // !!!!!!!
delay(500); //100
ina3221.begin();
// Set Relays status in lcd after reboot
lcd1.setCursor(0, 3);
lcd1.print("K1=");
lcd1.setCursor(5, 3);
lcd1.print("K2=");
lcd1.setCursor(8, 3);
lcd1.write(byte(0)); // SMILE
lcd1.setCursor(10, 3);
lcd1.print("K3=");
lcd1.setCursor(13, 3);
lcd1.print("G"); // INVERTER OFF
lcd1.setCursor(15, 3);
lcd1.print("K4=");
lcd1.setCursor(18, 3);
lcd1.print("X"); // GRID OFF
pinMode(ONBOARD_LED, OUTPUT); //ESP32 LED"
// Switches
pinMode(buttonPin12, INPUT_PULLUP); // not used
pinMode(buttonPin16, INPUT_PULLUP); // not used
pinMode(buttonPin23, INPUT_PULLUP); // Manually Lipo4 zu Lead acid aktivieren
pinMode(buttonPin18, INPUT_PULLUP); // not used
pinMode(buttonPin19, INPUT_PULLUP); // Manual Arduino RESET
// Smily K1 to K4 as output definiert
pinMode(26, OUTPUT); // K4 Fridge ON/OFF Inverter
pinMode(25, OUTPUT); // K3 Fridge ON/OFF 230V normal Power
pinMode(27, OUTPUT); // K2 not used
pinMode(13, OUTPUT); // K1 Lipo4 to Leadacid ON/OFF
pinMode(32, OUTPUT); // Alarm LED to pin 32
//By start all relays OFF
digitalWrite(26, HIGH); // K4(LED off) by start Arduino - NOT USED
digitalWrite(25, HIGH); // K3(LED on) by start Arduino - Fridge ON/OFF INVERTER (I) ?????????????????????
digitalWrite(27, HIGH); // K2(LED off) by start Arduino - K2 Inverter on/OFF ATS2
digitalWrite(13, HIGH); // K1(LED off) by start Arduino - K1 Lipo4 to Leadacid ON/OFF
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
if (WiFi.status() != WL_CONNECTED) {
lcd1.print(" ");
lcd1.print("WiFi lost......");
connectWiFi();
if (WiFi.status() == WL_CONNECTED) {
lcd1.print(" ");
lcd1.print(WiFi.localIP());
digitalWrite(ONBOARD_LED, HIGH);
digitalWrite(ONBOARD_LED, LOW);
// INA3221
busvoltage1 = ina3221.getBusVoltage_V(LEADACID_BATTERY_CHANNEL);
val2 = busvoltage1;
busvoltage2 = ina3221.getBusVoltage_V(LIPO_BATTERY_CHANNEL);
val5 = busvoltage2;
// TELEMETRY DATA LOGGER
float lead_acid = val2;
float lipo4 = val5;
char lead_acid_text[30];
char lipo4_text[30];
char solar1_text[30];
char solar2_text[30];
dtostrf(lead_acid, 10, 10, lead_acid_text);
dtostrf(lipo4, 10, 10, lipo4_text);
char text[125];
snprintf(text, 125, "%s,%s", lead_acid_text, lipo4_text);
Serial.println(text);
// Leadacid Battery %
vin1 = 100 * (val2 - 11.50) / (12.70 - 11.50);
if (val2 > 12.70) {
vin1 = 100;
// Lipo4 - Battery %
if (val5 >= 14.6) {
vin2 = 100;
} else if (val5 >= 13.6) {
vin2 = 99;
} else if (val5 >= 13.4) {
vin2 = 90;
} else if (val5 >= 13.3) {
vin2 = 70;
} else if (val5 >= 13.2) {
vin2 = 50;
} else if (val5 >= 13.1) {
vin2 = 40;
} else if (val5 >= 13.0) {
vin2 = 30;
} else if (val5 >= 12.9) {
vin2 = 20;
} else if (val5 >= 12.8) {
vin2 = 17;
} else if (val5 >= 12.5) {
vin2 = 14;
} else if (val5 >= 12.0) {
vin2 = 9;
} else if (val5 >= 10.0) {
vin2 = 0;
lcd1.setCursor(0, 1);
lcd1.print("Lipo4 :");
lcd1.setCursor(8, 1); // Lipo4 Volt
lcd1.print(val5);
lcd1.setCursor(16, 1);
lcd1.print(vin2);
lcd1.print("% ");
// Lead Acid Battery Voltage + Charge status
lcd1.setCursor(0, 0);
lcd1.print("Battery:");
lcd1.print(val2);
lcd1.setCursor(16, 0);
lcd1.print(vin1);
lcd1.print("%");
if (digitalRead(buttonPin19) == LOW) { //
resetFunc(); //call reset
// Fridge (INVERTER) On K3 (LED ON) Relay 1 NO
if (val2 > 12.80 && val2 < 14.60) {
digitalWrite(25, HIGH); // Fridge ON INVERTER (K3 = ON) (ATS Fridge)
lcd1.print("K3=");
lcd1.print("I"); // Inverter ON
if (val2 > 12.50 && val2 < 12.80) { // NUR ANZEIGE !!
lcd1.print("K3=");
if (val2 > 0.00 && val2 < 12.50) {
delay(100000);
} else if (val2 > 0.00 && val2 < 12.50) { //9% (becauseof voltage drop.Its still 14%)
digitalWrite(25, LOW); // Fridge ON GRID (K3 = OFF) (ATS)
lcd1.print("K3=");
// K2 Actually Cut off Inverter to activate ADS to switch to Grid
digitalWrite(27, HIGH); // K2 = OFF - Inverter ON
lcd1.print("K2=");
if (val2 < 11.80) {
delay(100000);
} else if (val2 < 11.80) {
digitalWrite(27, LOW); // K2 = ON - Inverter OFF
lcd1.print("K2=");
// K1 ON Lipo4 Battery (LED ON)
if (val2 > 12.70 && val2 < 14.60) {
digitalWrite(13, LOW); // K1 = ON = Lipo wird eingeschaltet
lcd1.print("K1=");
lcd1.setCursor(3, 3);
lcd1.write(byte(0)); // HAPPY
if (val2 > 12.40 && val2 < 12.70) { // NUR ANZEIGE !!
lcd1.print("K1=");
if (val2 < 12.40) {
delay(100000);
} else if (val2 < 12.40) {
digitalWrite(13, HIGH); // K1 = OFF = Lipo wird abgeschaltet
lcd1.print("K1=");
lcd1.write(byte(1)); // UNHAPPY
} // Program END
