I'm finishing up a design that adds external clamp diodes to prevent signals from going below ground or above Vcc (1st diode is anode on Gnd, cathode on input signal, 2nd diode is cathode on signal, anode to +5V). Would like to use the same diode across the Reset pullup resistor as well. Size is critical here as I am really tight on space. Two 0603s fit nicely along with some current limit resistors and small value caps to filter out high frequency noise.
What looks good here for this purpose? I'm inclined to just sort by price and then select something with <0.5V Vf to meet Vin >= -0.5V and <= Vcc+0.5V.
Maybe the 440mV @ 100mA parts.
0603
Hum. . .
Don't see the problem, on the other hand, I can' see them, way way to small for me.
I assume you will be installing them yourselves.
Have you done them before using your toaster oven?
How's your oven controller coming, I'm still interested?
