Need some advice on what type of sensor to use for measuring distance
I'm developing a device that requires some method of measuring distance roughly up to around 300mm. I was considering just using one of those cheap ultrasonic sensors.
The issue I have is that the device sits on top of a surface, my fear is that with an ultrasonic sensor its going to just deflect off the surface and give generally inaccurate readings. So ideally what I need is a sensor capable of measuring short distances with a wide horizontal FOV but a very narrow vertical FOV.
I also considered using some sort of laser however since the sensor would be almost at eye level I'm worried about potential eye damage.
You may be surprised. The ultrasonic sensors are cheap, so give it a try.
Do explain.
have a look at Pololu TOF sensors
Is the sensor looking horizontally along the surface or perpendicularly at the surface?
Keep in mind that sound waves obey the Law of Reflection (angle of incidence = angle of reflection), so it is very simple to analyze a given surface geometry and predict what to expect.
That's exactly what I was looking for, cheap and programmable FOV.
Out of curiosity, some of the models include "Zones", I assume that would mean I could program it to ignore, for example, any readings in a certain direction or "zone"?
