Need some advice regarding Touch panel code
Hi
Guys, trying to figue out for few days now,i have a display with resistive touch, problem is, that display is working fine, i`m using hardware mega spi pins, and utouch library for touch.
The problem is that i only receiving through serial coordinates x319, y 239.
Does any one came across any other library that might work with XPT2046, or is there any way i can use utouch?? tried calibration etc nothing works, i thought that this is hardware fault, but tried allready 3 different displays with the same chip and problem seems to be permanent.
My basic code to check touch:
#include <UTouch.h>
UTouch  myTouch( 14,15,16,17,18);
int x, y;
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_LOW);
  while(true)
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      Serial.print("x: ");
      Serial.print(x);
      Serial.print(" y: ");
      Serial.println(y);
      delay(100);
Also found this library, but don`t know how to use is as there is no examples for it.
Someone suggest to use ADS7846
thanks for any help.
  while(true)
Why are you running an infinite loop inside an infinite loop()?
This is how the library was written.
