Hey I'm new to the whole Arduino family and I'm trying to do a very simple project
1: have a push button to start the program
2: have the program stop once it done.
( from what i learned it's in a constant Loop)
3: have the program run a 20% duty cycle for 5sec, then 50% duty cycle for 5 sec and end with a 85% duty cycle for 5sec on one output.
4: have another button that i can press which would allow me to control the duty cycle with a potentiometer.
I have no problem getting it to start with a push button and to do the duty cycle, what I can't figure out is how to get the duty cycle to run for the five seconds, then switch to the next duty cycle and then stop
I suggest you set an integer variable, let's call it STEP, and set it's value initially to 0
When you press the start button have the program increment it to a 1 (stage 1)
Then have the first part of the program test for 'if STEP = 1 then (your first actions)
At the end of step 1 actions have the program increment STEP to value 2.
Clearly it will now ignore the STEP = 1 section of the code, and move on to the code which satisfies 'if STEP = 2'.
...and so on
At the end of the last step (you decide how many) make STEP = 0 again, and the program will wait for the pushbutton to be pressed before starting again.
As for the potentiometer modification, I'm sure better minds than mine will be along soon.
I can't help with the specific code as I'm a novice too!
Alexpaine:
You need to post your program so we can see what you have been trying.
#define LED 9 #define KNOB 0
const int buttonPin1 = 2; // the number of the pushbutton pin
const int buttonPin2 = 4; // second pushbutton
const int ledPin = 9; // for testing purpose will switch to relay later
int buttonState = 0;
buttonState = digitalRead(buttonPin1);
if (buttonState == HIGH) {
analogWrite(9, 64);
//need 5 sec run time
analogWrite(9, 127);
analogWrite(9, 215);
// need 5 sec run time
for(;;){} // i think this will prevent the loop from restarting?????
buttonState = digitalRead(buttonPin2);
// Read the value of the potentiometer knob
int knobValue = analogRead(KNOB);
// Map the potentiometer value to 1-255
int intensity = map(knobValue, 1, 1024, 1, 255);
// Output the respective value to the LED
analogWrite(LED, intensity);
What i would like it to do is "flash" the led for 5 Seconds at a certain flash rate pause flash LED for 5 seconds at a different pulse rate pause Flash the LED for 5 seconds at a different pulse rate and then stop flashing the LED all together and not repeat the loop
Im so lost... I have spent the last two hours reading and rereading all about delay millis, I've even tried watching YouTube videos and everything
I understand the concept behind the idea just not how to apply it.
Alexpaine:
I am learning very quickly that this is not as easy for me as I had thought..
I think sometimes people get stuck because they fail to realize a computer is utterly stupid - which means that a program must describe every little thing at a level of detail which would never be necessary with another human.
Robin2:
LOL so true. I recall a question not so long ago which was something like "why doesn't it switch off the LED after I release the button? I only tell it to switch on the LED when the button is pressed, so it should go off when not!"
Answer: "you never told the Arduino to switch off the LED, only to switch it on".
Indeed, you have to spell out everything for a computer, explicitly. They only do what you tell them to do, nothing more and nothing less.
The concept for this assignment is indeed a quite straightforward finite state machine. The trigger for cycling through the states is time (using the millis() timer); every state is doing something specific with your LED.
Robin2:
...R
You're very right I do know that computers are stupid and I feel just about as dumb as they are I'm putting my nose to the grindstone and going to see if I can find someone to help me
Such requests would normally go to the "gigs & collaborations" section, and have a price tag attached. Though not likely you'll find someone willing to do your school assignments for you.
wvmarle:
I kind of wish it was a school project because then I would have a teacher to show me how to do this
I'll put an ad in the gig section to see if I can find somebody thank you for the info.
