I wasn't guessing your gender, but the enthusiastic interjector.
This whole thread has been severely muddled by the unhelpful suggestions, 63 posts so far is just ridiculous. Let's get back to your OP.
Which is exactly what you have to do.
There are - as I understand it - three parts to your system. A song which is to be read from a table of notes (array), a LED pattern similarly read from an array, and a button to toggle the whole shebang on and off.
So your program loop needs to be a "state machine" involving three steps. Let's say the first step is to monitor the button. Has it just been pressed (that is, was previously not pressed and now is)? If so, a button timer (millis) is started. If it was started on a previous pass in the loop and is still pressed (otherwise it is cancelled), millis() is checked to see if it has been consistently pressed long enough (about 10 ms) to be a genuine press and if so, the "run/ stop" flag is toggled.
Next step: Check the song table. How long (millis) has the current note been playing? If not long enough, just keep playing it. If ready for the next note, OK, go to the next note.
Third step: Check the LED pattern table. How long (millis) has the current pattern been playing? If not long enough, just keep playing it. If ready for the next pattern, OK, go to the next pattern.
This loop() containing three steps keeps repeating forever. The second and third steps are of course dependent on the "run/ stop" flag; if it was set to "stop" then any note is switched off as is the LED pattern. You have an option here as to whether the button causes a pause or a re-start of the patterns.
Note that although there are other ways of doing it, the loop() runs extremely fast. It presumes you use the "tone" function to generate the sound independently of the main program and you only change the "tone" when you need to.
