i got some some confusing trouble that my code wont looping above 36000, when my data “X data” or “Y data” more than 4, my target pulse “jumlahpulsax” or “jumlahpulsay” wont count up and got floating in 16564,any suggestion why this could happen?
this is the code that wont run correctly
#include <EEPROM.h>
/* Blink without Delay
Turns on and off a light emitting diode(LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used herre to
// set pin numbers:
const int pulsex = 5; // the number of the LED pin
const int pulsey = 4;
const int PWMSpin = 7;
const int DIRx = 8;
const int DIRy = 9;
// Variables will change:
int pulseStatex = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
long previousMillis2 = 0;
int pulseStatey = LOW;
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 80; // interval at which to blink (milliseconds)
char flag=0;
int intervaly;
int intervaly_adr=200;
int intervalx;
int intervalx_adr=200;
uint16_t counterpulsex = 8000;
uint16_t counterpulsey = 8000;
int jumlahpulsax = 0;
int jumlahpulsay = 0;
int x0,x1,x2,x3,x4,x5,x6,x7,y0,y1,y2,y3,y4,y5,y6,y7;
int dx1,dx2,dx3,dx4,dx5,dx6,dx7,dy1,dy2,dy3,dy4,dy5,dy6,dy7;
int STEP; //shift register perhitungan
int n,o,p,hasil;
long m ;
long fm ; // fmax*fmax = 2500 * 2500 = 6250000;
long f;
int x,y;
// set the digital pin as output:
pinMode(pulsex, OUTPUT);
pinMode(pulsey, OUTPUT);
pinMode(PWMSpin, OUTPUT);
pinMode(DIRx, OUTPUT);
pinMode(DIRy, OUTPUT);
intervaly = EEPROM.read(intervaly_adr);
intervalx = EEPROM.read(intervalx_adr);
serial ();
stepper();
hitung ();
void stepper()
unsigned long currentMillis = micros();
if (jumlahpulsax <= counterpulsex*2)
if(currentMillis - previousMillis > intervalx) {
// save the last time you blinked the LED
jumlahpulsax++;
// if the LED is off turn it on and vice-versa:
if (pulseStatex == LOW)
pulseStatex = HIGH;
pulseStatex = LOW;
// set the LED with the ledState of the variable:
digitalWrite(pulsex, pulseStatex);
if (jumlahpulsay <= counterpulsey*2)
if(currentMillis - previousMillis2 > intervaly) {
previousMillis2 = currentMillis;
jumlahpulsay++;
//if the LED is off turn it on and vice-versa:
if (pulseStatey == LOW)
pulseStatey = HIGH;
pulseStatey = LOW;
digitalWrite(pulsey, pulseStatey);
void serial()
if (Serial.available())
flag=Serial.read();
if (flag=='a')
digitalWrite(8,HIGH);
if (flag=='b')
digitalWrite(8,LOW);
if (flag=='c')
digitalWrite(9,HIGH);
if (flag=='d')
digitalWrite(9,LOW);
if (flag=='m')
if (flag=='r')
jumlahpulsax = 0;
jumlahpulsay = 0;
if (flag=='e')
intervalx = Serial.parseInt();
Serial.print("Set: interval sumbu x ");
Serial.print(intervalx);
Serial.println("us.");
EEPROM.write(intervalx_adr, intervalx);
if (flag=='f')
intervaly = Serial.parseInt();
Serial.print("Set: interval sumbu y ");
Serial.print(intervaly);
EEPROM.write(intervaly_adr, intervaly);
void datamasuk()
void hitung()
fm = 6250000; // fmax*fmax = 2500 * 2500 = 625000
x=1; // input dx
y=2; // input dy
if (x<0){x=x*-1; digitalWrite(8,HIGH);}
if (y<0){y=y*-1; digitalWrite(9,HIGH);}
f= 1000000/(2*(sqrt(fm/(sq(x)+sq(y)))));
intervalx= f/x;
intervaly= f/y;
counterpulsex = 8000*x;
counterpulsey = 8000*y;
void langkah()
if (STEP == 1){
dx1 = x1 - x0;
dy1 = y2 - y0;
x=1; // input dx
y=2; // input dy
intervalx= f/x;
intervaly= f/y;
if (STEP == 2){
dx2 = x2 - x1;
dy2 = y2 - y1;
if (STEP == 3){
dx3 = x3 - x2;
dy3 = y3 - y2;
if (STEP == 4){
dx4 = x4 - x3;
dy4 = y4 - y3;
if (STEP == 5){
dx5 = x5 - x4;
dy5 = y5 - y4;
if (STEP == 6){
dx6 = x6 - x5;
dy6 = y6 - y5;
if (STEP == 7){
dx7 = x7 - x6;
dy7 = sqrt(y7 - y6);
and this one is the reference
float frek;
float steps = 0;
void setup ()
void loop ()
if (steps <= 40000)
steps++;
//frek = 2500 * 2500 ;
Serial.println(steps);
delayMicroseconds(10);}
