Hello colleagues, I am new to this and I need to make a program that works with several types of sensors (DHT11, DS3231, ACS712, GL55 and a potentiometer) and display the data on an LCD screen. I have the programs separately and they work, but I can't get them to work together, I think because the loops are not well defined. I attach my code so that you can take a look at it and you can help me in the failures that you see, thank you very much. Ignore the texts in spanish
#include <Wire.h>
#include "RTClib.h" //SCL(A5), SDA(A4), Vcc 5V,
#include <LiquidCrystal.h>
#include <DHT.h>
// Definimos el pin digital donde se conecta el sensor y el tipo de sensor
#define DHTPIN 6
#define DHTTYPE DHT11
LiquidCrystal lcd(12,11,5,4,3,2); // pines donde se conecta el lcd
RTC_DS3231 rtc;
DHT dht(DHTPIN, DHTTYPE); // Inicializamos el sensor DHT11
//se definen distintos tipos de variables del programa
String daysOfTheWeek[7] = { "Dom", "Lun", "Mar", "Mie", "Jue", "Vie", "Sab" };
String monthsNames[12] = { "Enero", "Febrero", "Marzo", "Abril", "Mayo", "Junio", "Julio","Agosto","Septiembre","Octubre","Noviembre","Diciembre" };
float sensibilidad = 0.185; // Sensibilidad del ACS712 en V/A, modelo 5A
float humedad;
float celsius;
float voltaje;
float intensidad;
float luz;
unsigned char seg=0;
unsigned char min=0;
unsigned char hor=0;
unsigned char date=0;
unsigned char month=0;
float year=0;
lcd.begin(16, 2); // Configuramos las columnas y filas del LCD 16x2
dht.begin(); // Comenzamos el sensor DHT
lcd.setCursor(0, 0);
lcd.print("¡Hola!");
delay(5000);
lcd.clear();
loop Reloj();
loop Voltaje();
loop Intensidad();
loop Luz();
loop Temperatura();
loop LCD();
void loop LCD() {
{//Escribimos la linea superior, la temperatura
lcd.setCursor(0,0);
lcd.print("Temperatura");
lcd.setCursor(13,0);
lcd.print(celsius);
lcd.setCursor(15,0);
lcd.print("ºC");
//Escribimos la linea inferior, la humedad
lcd.setCursor(0,1);
lcd.print("Humedad");
lcd.setCursor(9,0);
lcd.print(celsius);
lcd.setCursor(12,0);
lcd.print("%\t");
delay(2000); // 2 segundos hasta la siguiente medida.
lcd.clear(); //limpiamos la pantalla del LCD
{//Escribimos la linea superior de la siguiente medida, el voltaje
lcd.setCursor(0,0);
lcd.print("Voltaje");
lcd.setCursor(9,0);
lcd.print(voltaje, 2);
lcd.print("V");
//Escribimos la linea inferior, la intensidad
lcd.setCursor(0,1);
lcd.print("Intensidad");
lcd.print(intensidad, 2);
lcd.setCursor(16,0);
lcd.print("I");
{//Escribimos la linea superior, el nivel de luz
lcd.setCursor(0,0);
lcd.print("Nivel Luz");
lcd.setCursor(11,0);
lcd.print(luz);
lcd.print("%");
{//Escribimos la linea superior, el dia de la semana
lcd.setCursor(0,0);
lcd.print(date.year(), DEC);
lcd.setCursor(5,0);
lcd.print('/');
lcd.setCursor(6,0);
lcd.print(date.month(), DEC);
lcd.setCursor(8,0);
lcd.print('/');
lcd.setCursor(9,0);
lcd.print(date.day(), DEC);
lcd.print(daysOfTheWeek[date.dayOfTheWeek()]);
//Escribimos la linea inferior, la hora
lcd.setCursor(0,1);
lcd.print(date.hour(), DEC);
lcd.setCursor(3,0);
lcd.print(':');
lcd.setCursor(4,0);
lcd.print(date.minute(), DEC);
lcd.setCursor(6,0);
lcd.print(':');
lcd.setCursor(7,0);
lcd.print(date.second(), DEC);
void loopReloj() {
// Obtener fecha actual
DateTime now = rtc.now();
printDate(now);
delay(2000);
loop Voltaje() {
float sensorValue = analogRead(A1); // lee el input del sensor
float voltaje = sensorValue*5/1023; // convierte el valor a voltaje decimal
delay(2000);
loop Intensidad() {
float intensidad=get_corriente(200);//obtenemos la corriente promedio de 200 muestras
delay(2000);
float get_corriente(int n_muestras)
float voltajeSensor;
float corriente=0;
for(int i=0;i<n_muestras;i++)
voltajeSensor = analogRead(A2) * (5.0 / 1023.0);////lectura del sensor
corriente=corriente+(voltajeSensor-2.5)/sensibilidad; //Ecuación para obtener la corriente
corriente=corriente/n_muestras;
return(corriente);
loop Luz() {
int luz = map(analogRead(A0), 1023 ,0, 100 ,0);
// leemos el valor de la entrada analogica donde tenemos el LDR y lo guardamos en la variable luz
delay(2000);
loop Temperatura() {
float humedad = dht.readHumidity(); // Leemos la humedad relativa
float celsius = dht.readTemperature(); // Leemos la temperatura en grados celsius (por defecto)
delay(2000);// Esperamos 2 segundos entre medidas
