need some help keeping LEDs on
i am trying to get it to turn the LED on when i press the button and have it remain on until i press the off button.
it works just fine with pin 9, it turns on and remains on until i press the off button. but when i press any other buttons the LED only stays on while i am holding the button and turns off when i release it.
what am i missing here
any and all suggestions and help is welcome, im new to this...
pinMode(9,INPUT);
pinMode(10,INPUT);
pinMode(11,INPUT);
pinMode(12,INPUT);
pinMode(14,OUTPUT);
pinMode(15,OUTPUT);
pinMode(16,OUTPUT);
pinMode(17,OUTPUT);
if (digitalRead(9)==HIGH)
digitalWrite(14,HIGH);
if(digitalRead(10)==HIGH)
digitalWrite(15,HIGH);
if(digitalRead(11)==HIGH)
digitalWrite(16,HIGH);
{if(digitalRead(12)==HIGH)
digitalWrite(14,LOW);
digitalWrite(15,LOW);
digitalWrite(16,LOW);
    if (digitalRead(12) == HIGH)
      digitalWrite(14, LOW);
    digitalWrite(15, LOW);
    digitalWrite(16, LOW);
Which lines of code will be executed if pin 12 is HIGH ?
Which lines will be executed whatever the state of pin 12 ?
Are the line of code being executed the ones that you want ?
Note the code tags used when I pasted the code and also the code formatting when I used Tools/Auto Format in the IDE
if pin 12 is high then
will be executed
that function works fine from, its the turning them on that is the issue
Perhaps viewing that with a little better formatting will help.
    pinMode(9,  INPUT);
    pinMode(10, INPUT);
    pinMode(11, INPUT);
    pinMode(12, INPUT);
    pinMode(14, OUTPUT);
    pinMode(15, OUTPUT);
    pinMode(16, OUTPUT);
    pinMode(17, OUTPUT);
    if ( digitalRead(9) == HIGH )
        digitalWrite(14, HIGH);
    if ( digitalRead(10) == HIGH )
        digitalWrite(15, HIGH);
    if ( digitalRead(11) == HIGH )
        digitalWrite(16, HIGH);
        if ( digitalRead(12) == HIGH )
will be executed
Wrong
Will be executed regardless of the state of pin 12
ahh!
i see what you are saying.
how do i need to rewrite it then?
Put the statements to be executed when the condition is true in a pair of braces
Codieq742:
Change this:
To this:
IT WORKED!!
thank you.
why is it that it worked with
but not the others?
Without the braces only the next statement is executed. The braces denote a group of statements to be executed together.
The next thing to do is to write the sketch properly. You want the LEDs to change state when a switch BECOMES pressed, not IS pressed.
Look at the state change detection example.
