Need some help passing arrays
I've got a program where i'm trying to pass an array to a function, then print an element from that passed array. It only prints element 0.
I believe it has to do with pointers--which i really don't understand.
The attached code prints this (notice the missing element 1
start Black White Up Down Sensor Source End Black
Up
Sensor
Any help greatly appreciated.
const char *InvertText[2][3] = {{"Black"}, {"White"}};
const char *OrientationText[2][4] = {{"Up"}, {"Down"}};
const char *VoltInputText[2][6] = {{"Sensor"}, {"Source"}};
  // this works
  Serial.println("start");
  Serial.println(*InvertText[0]);
  Serial.println(*InvertText[1]);
  Serial.println(*OrientationText[0]);
  Serial.println(*OrientationText[1]);
  Serial.println(*VoltInputText[0]);
  Serial.println(*VoltInputText[1]);
  Serial.println("End");
    DumpText(*InvertText);
    DumpText(*OrientationText);
    DumpText(*VoltInputText);
    while(1){}
  void DumpText(const char *myarray[]) {
    // only element 0 prints
    Serial.println(myarray[0]);
    Serial.println(myarray[1]);
You have two dimensional arrays of pointers. Why? You only use one dimension.
You are printing the 2D arrays as though they were 1D arrays. Why?
it is easier than you made it...
char* InvertText[] = {"Black", "White"};  // an array of pointers to char arrays
char* OrientationText[] = {"Up", "Down"};
char* VoltInputText[] = {"Sensor", "Source"};
  Serial.println("start\n");
  Serial.println(InvertText[0]);
  Serial.println(InvertText[1]);
  Serial.println("End\n");
  DumpText(InvertText);
  DumpText(OrientationText);
  DumpText(VoltInputText);
  while (1) {}
void DumpText(char** myarray)  // weird, huh... a pointer to a pointer to a char (array)!!
@Bulldog: Given the way you've used it, would it be easier for a beginner to understand using this signature:
void DumpText(char* myarray[])
terms like better and easier are subjective.
econjack: @Bulldog: Given the way you've used it, would it be easier for a beginner to understand using this signature:
It's your prerogative to believe that but I think the other syntax is easier to grasp, it is a pointer to a pointer. Beginner needs to also be schooled that a passing and array name like that is simply resolving to a constant pointer.
KrisKasprzak: I believe it has to do with pointers--which i really don't understand.
Thanks bulldog, that did the trick
BulldogLowell:
It’s your prerogative to believe that but I think the other syntax is easier to grasp, it is a pointer to a pointer. Beginner needs to also be schooled that a passing and array name like that is simply resolving to a constant pointer.
Agreed, but if you think that, then why didn’t you write the function as:
  Serial.println(*myarray);
  Serial.println(*(myarray + 1));
True, it is subjective, but I’ve discussed this very topic with a number of my students and their feeling is that an array of pointers to char is more clear than a pointer to a pointer, especially when used with string data . I think the version above is harder to explain than your first version. I think you do, too, or you would have written it as above to show consistency with the function signature.
