Need some help with assembly language in code for morse transmitter [AM]
Hello there,
as my topic title says,
I got a question about some assembly code in the sketch that I have copied and edited,
From this topic:
I got ordered a lcd - keypad shield from a local seller yesterday, and have a problem with the ports that are needed for the lcd shield to work,
as I have read the code has assembly in it to set some ports as output (I think pin 8 - 13) and now I need to set this to pwm pin 3 on the digital pin header in order to get the transmitter to work hand in hand with the lcd shield,
can someone tell me how to do it?
so I can transmit on pin 3 and also have an working lcd
tnx already in advance,
Best Regards,
Bradley Methorst (DragonicDefson)
Maybe This Will Help:
long milliseconds_at_start = 0;
long milliseconds_at_end = 0;
const long length_transmitting_period = 8;
#define length_trans_dot 64
const int length_dot = length_trans_dot;
const int pause_dot = length_trans_dot;
const int length_dash = 3 * length_trans_dot;
const int pause_dash = length_trans_dot;
const int pause_words = 7 * length_trans_dot;
char * Letters[] =
 ".-", "-...", "-.-.", "-..", ".", "..-.", "--.", "....", "..",    // A-I
 ".---", "-.-", ".-..", "--", "-.", "---", ".--.", "--.-", ".-.",  // J-R
 "...", "-", "..-", "...-", ".--", "-..-", "-.--", "--.."          // S-Z
char * numbers[] = {"-----", ".----", "..---", "...--", "....-", ".....", "-....", "--...", "---..", "----."};
void dot (void);
void dash (void);
void pause (void);
void start_transmitting (int n_cycles);
void stop_transmitting (int n_cycles);
#define ASM_INC(reg) asm volatile ( "inc %0" : "=r" (reg) : "0" (reg))
  DDRD = DDRD|B00001000;
  milliseconds_at_start = millis();
  dot();
  milliseconds_at_end = millis();
  Serial.println( length_dot + (pause_dot * length_transmitting_period) * 256 / (milliseconds_at_end - milliseconds_at_start / 2 ));
  Serial.println( "\\-- BETTER_SOFTWARE_DEVELOPING MORSE_CODE PROJECT ANNO_2017 --//" );
  Serial.println( "[SYSTEM][ARDUINO]  [OI]POWER  ON[IO]  [ARDUINO][SYSTEM]" );
  Serial.println( "[TRANSMITTER] :FREQ :TRANSM|ITTING: FREQ: [TRANSMITTER]" );
  Serial.println( "[TRANSMITTER] :FREQUENCY:[KHZ]:FREQUENCY: [TRANSMITTER]" );
  Serial.println( "//-- BETTER_SOFTWARE_DEVELOPING MORSE_CODE PROJECT ANNO_2017 --\\" );
  Serial.println(length_dot + (pause_dot * length_transmitting_period) * 256 / (milliseconds_at_end - milliseconds_at_start / 2));
    if (Serial.available() > 0)
      char letter_number;
      letter_number = Serial.read();
      if (letter_number >= 'a' && letter_number <= 'z')
        transmit_sequence(Letters[letter_number - 'a']);
      else if (letter_number >= 'A' && letter_number <= 'Z')
        transmit_sequence(Letters[letter_number - 'A']);
      else if (letter_number >= '0' && letter_number <= '9')
        transmit_sequence(numbers[letter_number - '0']);
      else if (letter_number == ' ')
        pause();
  void transmit_sequence (char * sequence)
    int i = 0;
      while (sequence[i] != NULL)
        transmit_dot_dash (sequence[i]);
        i++;
  pause();
  void transmit_dot_dash (char dot_dash)
    if (dot_dash == '.')
      dot();
      dash();
  void dot (void)
    for (int i = 0; i < length_dot; i++)
      start_transmitting (length_transmitting_period);
    for ( int i = 0; i < pause_dot; i++)
      stop_transmitting (length_transmitting_period);
  void dash (void)
    for ( int i = 0; i < length_dash; i++ )
    for( int i = 0; i < pause_dash; i++ )
  void pause (void)
    for(int i = 0; i < pause_words; i++)
      unsigned int port_value;
      for (int i = 0; i < n_cycles; i++)
        port_value = 0;
      do
        PORTB = port_value;
        ASM_INC(port_value);
      while (port_value < 255);
      PORTD = B0000000;
        port_value = 0;
      do
        asm volatile ("NOP");
I know It needs some perfection, I’m working hardly on it :slight_smile:
