I have my new display up and running on an Arduino Uno. However, it appears the graphics that should be on the left, start in the middle and end on the right . Kind of like " )|( " instead of " () " if that makes since.
Here is the playground tutorial I used for wiring “using pin out B” http://www.arduino.cc/playground/Code/GLCDks0108
Here is my code found in a library example.
Any help would be great,
Mark
* ks0108 GLCDexample
* (example sketch from original ks0108 library)
* Basic test code for the Arduino KS0108 GLCD library.
* This code exercises a range of graphic functions supported
* by the library and is an example of its use.
* It also gives an indication of performance, showing the
* number of frames drawn per second.
#include <glcd.h>
#include "fonts/Arial14.h" // proportional font
#include "fonts/SystemFont5x7.h" // system font
#include "bitmaps/ArduinoIcon.h" // bitmap
//#include "include/glcd_Deprecated.h"
* Check for small displays as this code was written
* before small displays were supported.
#if DISPLAY_HEIGHT < 64
#error ks0108 example requires a display at least 64 pixels tall
#endif
#if DISPLAY_WIDTH < 128
#error ks0108 example requires a display at least 128 pixels wide
#endif
unsigned long startMillis;
unsigned int loops = 0;
unsigned int iter = 0;
void setup(){
GLCD.Init(NON_INVERTED); // initialise the library, non inverted writes pixels onto a clear screen
GLCD.ClearScreen();
GLCD.DrawBitmap(ArduinoIcon, 32,0, BLACK); //draw the bitmap at the given x,y position
GLCD.SelectFont(System5x7); // switch to fixed width system font
countdown(5);
GLCD.ClearScreen();
introScreen(); // show some intro stuff
GLCD.ClearScreen();
void introScreen(){
GLCD.SelectFont(Arial_14); // you can also make your own fonts, see playground for details
GLCD.GotoXY(20, 2);
GLCD.Puts("GLCD version ");
GLCD.PrintNumber(GLCD_VERSION);
GLCD.DrawRoundRect(16,0,99,18, 5, BLACK); // rounded rectangle around text area
showCharacters();
countdown(5);
void showCharacters(){
byte line = 3; // start on the fourth line
for(byte c = 32; c <=127; c++){
if( (c-32) % 20 == 0)
GLCD.CursorTo(1,line++); // CursorTo is used for fixed width system font
GLCD.PutChar(c);
void drawSpinner(byte pos, byte x, byte y) {
// this draws an object that appears to spin
switch(pos % 8) {
case 0 : GLCD.DrawLine( x, y-8, x, y+8, BLACK); break;
case 1 : GLCD.DrawLine( x+3, y-7, x-3, y+7, BLACK); break;
case 2 : GLCD.DrawLine( x+6, y-6, x-6, y+6, BLACK); break;
case 3 : GLCD.DrawLine( x+7, y-3, x-7, y+3, BLACK); break;
case 4 : GLCD.DrawLine( x+8, y, x-8, y, BLACK); break;
case 5 : GLCD.DrawLine( x+7, y+3, x-7, y-3, BLACK); break;
case 6 : GLCD.DrawLine( x+6, y+6, x-6, y-6, BLACK); break;
case 7 : GLCD.DrawLine( x+3, y+7, x-3, y-7, BLACK); break;
void countdown(int count){
while(count--){ // do countdown
GLCD.CursorTo(0,1); // first column, second row (offset is from 0)
GLCD.PutChar(count + '0');
void loop(){ // run over and over again
iter = 0;
startMillis = millis();
while( millis() - startMillis < 1000){ // loop for one second
GLCD.DrawRect(0, 0, 64, 61, BLACK); // rectangle in left side of screen
GLCD.DrawRoundRect(68, 0, 58, 61, 5, BLACK); // rounded rectangle around text area
for(int i=0; i < 62; i += 4)
GLCD.DrawLine(1,1,63,i, BLACK); // draw lines from upper left down right side of rectangle
GLCD.DrawCircle(32,31,30,BLACK); // draw circle centered in the left side of screen
GLCD.FillRect(92,40,16,16, WHITE); // clear previous spinner position
drawSpinner(loops++,100,48); // draw new spinner position
//GLCD.FillRect(24,txtLINE3,14,14, WHITE); // clear text area that will be drawn below
GLCD.CursorTo(5,5); // locate curser for printing text
GLCD.PrintNumber(++iter); // print current iteration at the current cursor position
// display number of iterations in one second
GLCD.ClearScreen(); // clear the screen
GLCD.CursorTo(14,2); // positon cursor
GLCD.Puts("FPS= "); // print a text string
GLCD.PrintNumber(iter); // print a number
