I’m currently making a 2 key keypad for myself with a pro micro. I’m trying to use the keyboard function to let it print out an ASCII code at the press of a button. Instead of writing 1 character, it writes a lot of them. What did I do wrong?
#include <Keyboard.h>
pinMode(2, INPUT_PULLUP);
pinMode(3,INPUT_PULLUP);
Keyboard.begin();
if (digitalRead(2) == LOW) {
Keyboard.write(122);
if (digitalRead(3) == LOW)
Keyboard.write(89);
loop() repeats very quickly so your digitalRead()s repeat very quickly
You need to detect when an input goes LOW rather than when it is LOW
See the StateChangeDetection example in the IDE
There is an error in the placement of the braces ({) and the ifs.
Use a lock to prevent key repetition.
example:
pinMode(3, INPUT_PULLUP);
Keyboard.begin();
while (digitalRead(2) == LOW)
if (digitalRead(2) == HIGH)
while (digitalRead(3) == LOW)
if (digitalRead(3) == HIGH)
Keyboard.write(89);
RV mineirin
will pin 2 ever be HIGH while pin 2 is LOW ?
UKHeliBob You are right,
now I wrote like this:
Keyboard.begin();
delay(30);
while (digitalRead(2) == LOW) {}
delay(30);
Keyboard.write(89);
while (digitalRead(3) == LOW) {}
system
Closed
September 4, 2021, 9:15pm
#7
