Need some help with my EMF detector
Im a student of graphic design in Detroit, and i could really use some help.
disclaimer im SUPER new to using Arduino but i have doing a lot of reading.
So i found this project : aaronalai.com/emf-detector <----- real cool
  • I built it and thats all gravy
The problem: I wanna be able to read the EMF signals in flash using the NETLab Widget tool kit (analoginput). I THINK I i need to add something to the sketch because none of the data is making it to Flash.
WHAT IM USING:
-Arduino (sketch app)
-NETLabHub
-NETLab Toolkit AS3 Widgets
-Flash CS4
THE CODE IM USING NOW:
int inPin = 5; // analog 5
int val = 0; // where to store info from analog 5
int pin11 = 11; // output of red led
val = analogRead(inPin); // reads in the values from analog 5 and
//assigns them to val
if(val >= 1){
val = constrain(val, 1, 100); // mess with these values
val = map(val, 1, 100, 1, 255); // to change the response distance of the device
analogWrite(pin11, val); // *note also messing with the resistor should change
// the sensitivity
}else{ // analogWrite(pin11, val); just tuns on the led with
// the intensity of the variable val
analogWrite(pin11, 0); // the else statement is just telling the microcontroller
// to turn off the light if there is no EMF detected
Serial.println(val); // use output to aid in calibrating
CHEERS - THANKS FOR YOUR TIME
http://www.arduino.cc/playground/Interfacing/Flash
