Need some help with my RTC 1340.
Before I ask my question. I am completely new to Arduino and RTC in general so if I am asking in the wrong place I am sorry.
I am trying to get an RTC running for a project I am hoping to build. My RTC is a ds1340, also it is not a premade board I soldered the chip with a crystal and have a super cap as power backup. I am having trouble validating its operation. I have downloaded so many sketches and libraries to see if it is working.
I have a sketch that is called I2C scanner and it uploads to arduino fine and the serial monitor gives me a valid response, i think-I2C device found at address 0x68.
I also found a blog from a person that has a ds1340 and he used a library from a ds3231 and got it to work. So i downloaded the library and it loaded up on the arduino. So i open the serial monitor and it is giving me a scan every second for time and date and alarm, but the time never changes. I am also not really sure how to set the time in the sketch to be honest.
Even on google search it does not seem like very many people use the 1340, from what I understand the 1340 and 3231 are really similar, I even tried the official libraries for the 1340. I am not sure where to go from here. I know it is probably something simple that I don't know how to do.
Here is the link to the library I used.[Arduino #20] JeeLabs RTC DS1340 tutorial for dummies | Curious Seyoung
Here is the 3231_Test code I was using for feedback in the serial monitor, also there is a 3231_Set in the library.
DS3231_test.pde
Eric Ayars
4/11
Test/demo of read routines for a DS3231 RTC.
Turn on the serial monitor after loading this to check if things are
working as they should.
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
	// Start the I2C interface
	Wire.begin();
	// Start the serial interface
	// send what's going on to the serial monitor.
	// Start with the year
	Serial.print("2");
	if (Century) {			// Won't need this for 89 years.
		Serial.print("1");
		Serial.print("0");
	Serial.print(Clock.getYear(), DEC);
	Serial.print(' ');
	// then the month
	Serial.print(Clock.getMonth(Century), DEC);
	Serial.print(' ');
	// then the date
	Serial.print(Clock.getDate(), DEC);
	Serial.print(' ');
	// and the day of the week
	Serial.print(Clock.getDoW(), DEC);
	Serial.print(' ');
	// Finally the hour, minute, and second
	Serial.print(Clock.getHour(h12, PM), DEC);
	Serial.print(' ');
	Serial.print(Clock.getMinute(), DEC);
	Serial.print(' ');
	Serial.print(Clock.getSecond(), DEC);
	// Add AM/PM indicator
	if (h12) {
		if (PM) {
			Serial.print(" PM ");
			Serial.print(" AM ");
		Serial.print(" 24h ");
	// Display the temperature
	Serial.print("T=");
	Serial.print(Clock.getTemperature(), 2);
	// Tell whether the time is (likely to be) valid
	if (Clock.oscillatorCheck()) {
		Serial.print(" O+");
		Serial.print(" O-");
	// Indicate whether an alarm went off
	if (Clock.checkIfAlarm(1)) {
		Serial.print(" A1!");
	if (Clock.checkIfAlarm(2)) {
		Serial.print(" A2!");
	// New line on display
	Serial.print('\n');
	// Display Alarm 1 information
	Serial.print("Alarm 1: ");
	Clock.getA1Time(ADay, AHour, AMinute, ASecond, ABits, ADy, A12h, Apm);
	Serial.print(ADay, DEC);
	if (ADy) {
		Serial.print(" DoW");
		Serial.print(" Date");
	Serial.print(' ');
	Serial.print(AHour, DEC);
	Serial.print(' ');
	Serial.print(AMinute, DEC);
	Serial.print(' ');
	Serial.print(ASecond, DEC);
	Serial.print(' ');
	if (A12h) {
		if (Apm) {
			Serial.print('pm ');
			Serial.print('am ');
	if (Clock.checkAlarmEnabled(1)) {
		Serial.print("enabled");
	Serial.print('\n');
	// Display Alarm 2 information
	Serial.print("Alarm 2: ");
	Clock.getA2Time(ADay, AHour, AMinute, ABits, ADy, A12h, Apm);
	if (ADy) {
	Serial.print(' ');
	Serial.print(' ');
	Serial.print(' ');
	if (A12h) {
		if (Apm) {
			Serial.print('pm');
			Serial.print('am');
	if (Clock.checkAlarmEnabled(2)) {
	// display alarm bits
	Serial.print('\nAlarm bits: ');
	Serial.print(ABits, BIN);
	Serial.print('\n');
	Serial.print('\n');
Any one have any ideas
Hi .. I'm using an RTC FM3164 and I just need to read and write the FRAM, but I can not get it. Could you do that? I use thousands of libraries and I do not have a positive result.
