Need some help with TFT 320QUT LCD Touch
I have connected my TFT 320QUT LCD Touch module directly to my Arduino MEGA 2560 using the guide form this post http://arduino.cc/forum/index.php/topic,101029.0.html
I have downloaded and installed these libraries ITDB02_Graph;UTFT and ITDB02_Touch to my Arduino 1.0.
Using the examples from the UTFT library the display works just perfectly.
For the ITDB02_Touch library examples I cannot compile the codes, they give me lots of errors.
According to this page Electronics - Henning Karlsen I need ITDB02 Arduino Shield or MEGA Shield
Do I really need the ITDB02 Arduino Shield for the touchscreen to work or is it possible to connect the pins of my TFT module directly to my Arduino MEGA 2560 and change something in the example code for the touchscreen to work??
Here’s the code for the ITDB02_Touch library exaples
// ITDB02_Touch_Calibration (C)2010 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program can be used to calibrate the touchscreen
// of the ITDB02 modules.
// This program requires the ITDB02_Graph library (8bit mode)
// or ITDB02_Graph16 (16bit mode).
// It is assumed that the ITDB02 module is connected to a
// ITDB02 Shield, a ITDB02 Mega Shield or that you know how
// to change the pin numbers in the setup.
// Instructions will be given on the display.
// Remember to change the next line if you are using as 16bit module!
#include <ITDB02_Graph.h>
#include <ITDB02_Touch.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next two lines for the ITDB02 Shield
//ITDB02        myGLCD(19,18,17,16);
//ITDB02_Touch  myTouch(15,10,14,9,8);
// Uncomment the next two lines for the ITDB02 Mega Shield
ITDB02        myGLCD(38,39,40,41);   // Remember to add ASPECT_16x9 if you are using an ITDB02-3.2WC!
ITDB02_Touch  myTouch(6,5,4,3,2);
int cx, cy;
int rx[10], ry[10];
float px, py;
int ox, oy;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_LOW);
void drawCrossHair(int x, int y)
  myGLCD.drawRect(x-10, y-10, x+10, y+10);
  myGLCD.drawLine(x-5, y, x+5, y);
  myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
  int iter = 2000;
  int cnt = 0;
  unsigned long tx=0;
  unsigned long ty=0;
  boolean OK = false;
  while (OK == false)
    while (myTouch.dataAvailable() == false) {}
    while ((myTouch.dataAvailable() == true) && (cnt<iter))
      myTouch.read();
      tx += myTouch.TP_X;
      ty += myTouch.TP_Y;
      cnt++;
    if (cnt>=iter)
      OK = true;
      tx = 0;
      ty = 0;
      cnt = 0;
  cx = tx / iter;
  cy = ty / iter;
void calibrate(int x, int y, int i)
  myGLCD.setColor(255, 255, 255);
  drawCrossHair(x,y);
  readCoordinates();
  myGLCD.setColor(80, 80, 80);
  drawCrossHair(x,y);
  rx[i]=cx;
  ry[i]=cy;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
void waitForTouch()
    myTouch.read();
    myTouch.read();
void startup()
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.drawLine(0, 14, 239, 14);
  myGLCD.print("ITDB02 TOUCH CALIBRATION", CENTER, 1);
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.print("INSTRUCTIONS", CENTER, 30);
  myGLCD.print("Use a stylus or something", LEFT, 50);
  myGLCD.print("similar to touch as close to", LEFT, 62);
  myGLCD.print("the center of the highlighted", LEFT, 74);
  myGLCD.print("crosshair as possible. Keep as", LEFT, 86);
  myGLCD.print("still as possible and keep", LEFT, 98);
  myGLCD.print("holding until the highlight is", LEFT, 110);
  myGLCD.print("removed. Repeat for all", LEFT, 122);
  myGLCD.print("crosshairs in sequence.", LEFT, 134);
  myGLCD.print("Further instructions will be", LEFT, 158);
  myGLCD.print("displayed when the calibration", LEFT, 170);
  myGLCD.print("is complete.", LEFT, 182);
  myGLCD.print("Do NOT use your finger as a", LEFT, 206);
  myGLCD.print("calibration stylus or the", LEFT, 218);
  myGLCD.print("result WILL BE very imprecise.", LEFT, 230);
  myGLCD.print("Touch screen to continue", CENTER, 305);
  waitForTouch();
  myGLCD.clrScr();
void done()
  myGLCD.clrScr();
  myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
  myGLCD.print("To use the new calibration", LEFT, 50);
  myGLCD.print("settings you must edit the", LEFT, 62);
  myGLCD.setColor(160, 160, 255);
  myGLCD.print("ITDB02_Touch.cpp", LEFT, 74);
  myGLCD.print("file and", 136, 74);
  myGLCD.print("change the following values.", LEFT, 86);
  myGLCD.print("The values are located right", LEFT, 98);
  myGLCD.print("below the opening comment in", LEFT, 110);
  myGLCD.print("the file.", LEFT, 122);
  myGLCD.print("PixSizeX", LEFT, 158);
  myGLCD.print("PixOffsX", LEFT, 170);
  myGLCD.print("PixSizeY", LEFT, 182);
  myGLCD.print("PixOffsY", LEFT, 194);
  myGLCD.print("Connected module:", LEFT, 250);
  myGLCD.drawLine(0, 155, 239, 155);
  myGLCD.drawLine(0, 209, 239, 209);
  myGLCD.printNumF(px, 2, 100, 158);
  myGLCD.printNumI(ox, 100, 170);
  myGLCD.printNumF(py, 2, 100, 182);
  myGLCD.printNumI(oy, 100, 194);
  if (px>=0)
    myGLCD.print("2.4\"", 144, 250);
    if (py>=0)
      myGLCD.print("3.2\"", 144, 250);
      myGLCD.print("Negative numbers for PixSizeX", LEFT, 270);
      myGLCD.print("is expected :)", LEFT, 282);
      myGLCD.print("3.2\" Wide", 144, 250);
      myGLCD.print("and PixSizeY are expected :)", LEFT, 282);
  startup();
  drawCrossHair(10,10);
  drawCrossHair(10,160);
  drawCrossHair(10,309);
  drawCrossHair(120,10);
  drawCrossHair(120,160);
  drawCrossHair(120,309);
  drawCrossHair(229,10);
  drawCrossHair(229,160);
  drawCrossHair(229,309);
  calibrate(10, 10, 0);
  calibrate(10, 160, 1);
  calibrate(10, 309, 2);
  calibrate(120, 10, 3);
  calibrate(120, 160, 4);
  calibrate(120, 309, 5);
  calibrate(229, 10, 6);
  calibrate(229, 160, 7);
  calibrate(229, 309, 8);
  px = ((float(rx[0]+rx[1]+rx[2])/3)-(float(rx[6]+rx[7]+rx[8])/3))/220;
  if (px>=0)
    ox = (((rx[6]+rx[7]+rx[8])/3))-(px*10);
    ox = (((rx[0]+rx[1]+rx[2])/3))+(px*10);
  py = ((float(ry[0]+ry[3]+ry[6])/3)-(float(ry[2]+ry[5]+ry[8])/3))/300;
  if (py>=0)
    oy = (((ry[2]+ry[5]+ry[8])/3))-(py*10);
    oy = (((ry[0]+ry[3]+ry[6])/3))+(py*10);
  done();
  while(true) {}
And here’s the errors:
C:\Users\a\Desktop\arduino-1.0-windows\arduino-1.0\libraries\ITDB02_Graph\ITDB02_Graph.cpp:39:22: error: WProgram.h: No such file or directory
Hey, I just had the same problem with the libraries.
Found the fix, go into the file; C:\Users\a\Desktop\arduino-1.0-windows\arduino-1.0\libraries\ITDB02_Graph\ITDB02_Graph.cpp
and also the same director but the .h file, and change the "WProgram.h" line to "Arduino.h"
Do this for the ITDB02_Graph and ITDB02_Touch library, and then the code will compile fine. :)
