Need some help
Hey,
Since yesterday I can't upload anything to my dragino/Yun LG01 anymore. Already did some searching, checked the mentioned bridge.h file, but I can't find any fault in there. Did a complete reinstall of my arduino IDE including libs and board. Did a full reset on the dragino. Non of this work. This is what the IDE returns to me. Can anyone point me in the direction to look?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\libraries\Bridge\src\Bridge.h: In member function 'transfer':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\libraries\Bridge\src\Bridge.h:56:5: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.19.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Fout bij het compileren voor board Dragino Yún + UNO or LG01/OLG01
This bug is specific to the 5.4.0-atmel3.6.1-arduino2 version of avr-gcc used by Arduino AVR Boards 1.6.22 and newer. It has been reported here:
Here's the workaround:
  • Tools > Board > Boards Manager
  • Wait for downloads to finish.
  • When you move the mouse pointer over "Arduino AVR Boards", you will see a "Select version" dropdown menu appear. Select "1.6.21".
  • Click "Install".
  • Wait for installation to finish.
  • Click "Close".
Due to a bug, this workaround doesn't work with Arduino IDE 1.8.6, but it will work with any other version of the Arduino IDE.
If you have File > Preferences > Check for updates on startup checked, the Arduino IDE may occasionally notify you that a new version of Arduino AVR Boards is available, you'll need to refrain from updating back to the new Arduino AVR Boards version, otherwise you'll be back to seeing the segmentation fault error again.
There is also a beta test version of the next release of Arduino AVR Boards, which uses a new version of avr-gcc which is supposed to have the bug fixed. If you feel like using that solution instead of the workaround instructions above, you'll find information in the GitHub issue report.
Thank you sir,
This solved my issue
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
