need some help
so i am trying to build a arduino that uses photoresistors to move the mouse, i am using aac keys as the gobetween. now i have a problem, i want to move the arduino depending on the resistance of the photoresistor, here's a portion of my code, part of void loop(), where there is the problem.
Serial.print("\033,move,  analogRead(photosensorPin)/20, 0.");
i am trying to move the mouse to the right x-coordinate depending on the value of the photosensor pin, however the problem is that since analogRead(photosensorPin)/20 is inside quotations, it read it a string, and does not take the value. however, i need the x coord aka analogRead(photosensorPin)/20 to be inside quotations for it to work since it has to adhere to this format:
<SERIAL-MARKER><esc>,move,+5,0.      //Moves the mouse cursor 5 pixels to the right.
anyone knows a way to solve this problem? to make the software read the value of the function inside quotations and not take it as a literal? anyone tried to use aakeys and arduino to use it as a mouse before and have encountered this?
i found a solution, but it's slow, i was wndering if anyone knew of a fast way;
here's my solution:
 Serial.print("\033, move,");
  Serial.print(val);
  Serial.print (", 0.");
in c++ you could do something like
 cout << "hehie" << val << "ok";
it is possible to do the same in the arduino sofware?
Yes, but why would it be any faster?
The slow bit is the serial transmission.
At 9600 baud (you haven't told us what serial rate you're using: hint), one bit (and there are ten bits for every character that you print) takes as long to transmit as it takes the processor to read a single analogue value.
"Yes, but why would it be any faster?"
so how do i do that if you said it's possible?
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1231224786
