I’ve been working on an autonomous boat lately to participate into the Microtransat race in 2017. So far so good, except for the code. I took it from the internet, and it works like a charm, except for the fact that it uses motors for steering. I need it to use servo-motors.
Since the TinyGPS++ library forbids the use of the default <Servo.h> library, <PWMServo.h> will be used instead.
Here’s the code (there are actually two codes, this one defines the steering):
#include <Wire.h>
#include "compass.h"
#include <SoftwareSerial.h>
#include <SoftEasyTransfer.h>
#include <Average.h>
#include "LowPower.h"
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/io.h>
//Motor Control
int maxspeed;
//maxspeed - motgain * 30 > 0
//MOTGAIN 4
int motgain = 4;
int anglerange = 30;
int rightpin = 10;
int leftpin = 9;
int led = 13;
int overavg = 10;
int steerarray[10];
int throttlearray[10];
//GPS
static int r = 6371;
const float Pi = 3.14159;
int accuracy = 5;
unsigned long lasttime = 0;
SoftEasyTransfer rx;
SoftwareSerial link(7, 8);
struct RECEIVE_DATA_STRUCTURE{
float latitude;
float longitude;
RECEIVE_DATA_STRUCTURE gpsin;
Wire.begin();
pinMode(rightpin, OUTPUT);
pinMode(leftpin, OUTPUT);
pinMode(led, OUTPUT);
compass_init(2);
compass_debug = 1;
compass_offset_calibration(3);
link.begin(38400);
rx.begin(details(gpsin), &link);
digitalWrite(led, HIGH);
Navigate(49.231623, -122.695656, 80);
Navigate(49.231600, -122.695745, 80);
Navigate(49.231545, -122.695796, 80);
Navigate(49.231474, -122.695756, 80);
Navigate(49.231450, -122.695659, 80);
Navigate(49.231472, -122.695568, 80);
Navigate(49.231535, -122.695523, 80);
Navigate(49.231600, -122.695572, 80);
//Control();
void Control() {
while (pulseIn(5, HIGH, 100000) > 0){
int throttle = pulseIn(4, HIGH, 20000);
int steer = pulseIn(5, HIGH, 20000);
if (throttle > 1000 && steer > 1000) {
Override(throttle, steer);
delay(50);
void Navigate(float lat2, float long2, int velocity) {
maxspeed = velocity;
while (GetDistanceInM(gpsin.latitude, gpsin.longitude, lat2, long2) > accuracy) {
if (rx.receiveData()){
lasttime = millis();
delay(50);
if ((millis() - lasttime) < 2000) {
int bearing = GetBearing();
int heading = GetHeading(gpsin.latitude, gpsin.longitude, lat2, long2);
int leftmot = MotorSpeed(bearing, heading, 1);
int rightmot = MotorSpeed(bearing, heading, 0);
if (leftmot < 0) {
leftmot = 0;
if (rightmot < 0) {
rightmot = 0;
RunMotor(leftmot, 1);
RunMotor(rightmot, 0);
Serial.print(bearing);
Serial.print(" ");
Serial.print(heading);
Serial.print(" ");
Serial.print(GetDistanceInM(gpsin.latitude, gpsin.longitude, lat2, long2));
Serial.print(" ");
Serial.print(leftmot);
Serial.print(" ");
Serial.println(rightmot);
else {
RunMotor(0, 1);
RunMotor(0, 0);
Serial.println("No GPS Signal");
Serial.println("NavLoop Return");
RunMotor(0, 1);
RunMotor(0, 0);
void Override(int throttle, int steering) {
int left;
int right;
if (throttle > 1600)
throttle = (int)(0.51 * (throttle - 1500));
if (steering > 1500) {
right = (int)(throttle - 0.51* (steering - 1500));
if (right < 0)
right = 0;
left = throttle;
else {
left = (int)(throttle + 0.51 * (steering - 1500));
if (left < 0)
left = 0;
right = throttle;
else {
left = 0;
right = 0;
RunMotor(right, 0);
RunMotor(left, 1);
Serial.print(left);
Serial.print(" ");
Serial.println(right);
void RunMotor(int val, int option){
if (option == 0) {
//Right Motor
analogWrite(rightpin, val);
else {
//Left Motor
analogWrite(leftpin, val);
int GetBearing() {
compass_heading();
float headingradians = bearing / (180 / M_PI);
float declinationAngle = 0.289724656;
headingradians += declinationAngle;
bearing = (int)((headingradians * 180 / M_PI)+270) % 360;
return bearing;
int MotorSpeed(int bearing, int heading, int option) {
heading = heading % 360;
bearing = bearing % 360;
if (heading == bearing)
return (maxspeed);
int o1 = (int)heading - (int)bearing;
int o2 = (int)bearing - (int)heading;
int direction = ((360 - ((int)heading - (int)bearing)) % 360);
if (direction < 180) {
if (direction > anglerange)
//Right Motor
if (option == 0) {
return maxspeed;
//Left Motor
else {
return 0;
//Right Motor
if (option == 0) {
return maxspeed;
//Left Motor
else {
return maxspeed - (direction * motgain);
else if (direction >= 180)
if ((360 - direction) > anglerange)
//Right Motor
if (option == 0) {
return 0;
//Left Motor
else {
return maxspeed;
//Right Motor
if (option == 0) {
return maxspeed - ((360 - direction) * motgain);
//Left Motor
else {
return maxspeed;
return 0;
static float GetHeading(float lat1, float long1, float lat2, float long2)
//Current Latitude, Current Longitude
//Projected Latitude, Projected Longitude
//To get reverse heading, add 180
lat1 = ConvertToRadians(lat1);
lat2 = ConvertToRadians(lat2);
long1 = ConvertToRadians(long1);
long2 = ConvertToRadians(long2);
float dLon = long2 - long1;
float y = sin(dLon) * cos(lat2);
float x = cos(lat1) * sin(lat2) - sin(lat1) * cos(lat2) * cos(dLon);
return ConvertToStaticDegrees(atan2(y, x));
static float GetDistanceInM(float lat1, float long1, float lat2, float long2)
float dLat = lat2 - lat1;
float a = haversin(dLat) + cos(lat1) * cos(lat2) * haversin(dLon);
float c = 2 * atan2(sqrt(a), sqrt(1 - a));
return r * c * 1000; // Distance in M
static float ConvertToDegrees(float rad)
float degrees = rad / (Pi / 180);
if (degrees <= -180) {
return degrees + 360;
else {
return degrees;
static float ConvertToStaticDegrees(float rad)
if (degrees <= 0) {
else {
return degrees;
static float ConvertToRadians(float angle)
return (Pi / 180) * angle;
static float haversin(float input)
return (sin(input / 2)) * (sin(input / 2));
Thanks a lot!
