I’m using an Arduino Mega2560 to control some neopixels but there seems to be a bug that i can’t fined
in the video you can see it working for the first 7 seconds then the left pixels stop turning off and don’t update right. it dose this after i turn on the arduino about 50% of the time i don’t think its sram and I’m getting no error messages
I added the files so you can see all the code that I’m running i add a function to adafruit called setnumpixals();
[/code]
void centeractive(){
bars();
drop();
if(lefttimer3<(millis()-100)){
lefttimer3 = millis();
getcolor();
shifttwo();
addnewcolor();
arraytostrip();
stripleft.show();
stripright.show();
/// take the lastleft and lastright from bars() and drop() turns them into a usable color
void getcolor(){
Serial.println("getcolor");
// dettermen the new color and assign to color
if(lastleft>=7){
/// perple
colorleft = stripleft.Color(255,0,130);
}else if(lastleft>=5){
// red
colorleft = stripleft.Color(255,0,0);
}else if(lastleft>=4){
// blue
colorleft = stripleft.Color(0,0,255);
}else if(lastleft>=3){
// green
colorleft = stripleft.Color(0,255,0);
}else if(lastleft>=1){
// yellow
colorleft = stripleft.Color(255,125,0);
}else if(lastleft>=0){
// wight
colorleft = stripleft.Color(200,200,200);
// dettermen the new color and assign to colorright
if(lastright>=7){
// perple
colorright = stripright.Color(255,0,130);
}else if(lastright>=5){
///red
colorright = stripright.Color(255,0,0);
}else if(lastright>=4){
// blue
colorright = stripright.Color(0,0,255);
}else if(lastright>=3){
// green
colorright = stripright.Color(0,255,0);
}else if(lastright>=1){
// yellow
colorright = stripright.Color(255,125,0);
}else if(lastright>=0){
// wight
colorright = stripright.Color(200,200,200);
/// moves the array into the other array
void arraytostrip(){
for(int i=0;i<half;i++){
if(i<lastright){
stripright.setPixelColor(i,top_arrayright[i]);
stripright.setPixelColor(i+1,top_arrayright[i+1]);
stripright.setPixelColor((stripright.numPixels()-i)-1,bottom_arrayright[i]);
stripright.setPixelColor((stripright.numPixels()-i)-2,bottom_arrayright[i+1]);
}else{
stripright.setPixelColor(i,off);
stripright.setPixelColor(i+1,off);
stripright.setPixelColor((stripright.numPixels()-i)-1,off);
stripright.setPixelColor((stripright.numPixels()-i)-2,off);
i++;
if(i<lastleft){
stripleft.setPixelColor(i,top_arrayleft[i]);
stripleft.setPixelColor(i+1,top_arrayleft[i+1]);
stripleft.setPixelColor((stripright.numPixels()-i)-1,bottom_arrayleft[i]);
stripleft.setPixelColor((stripright.numPixels()-i)-2,bottom_arrayleft[i+1]);
}else{
//Serial.println(stripleft.numPixels()-i-1);
stripleft.setPixelColor(i,off);
stripleft.setPixelColor(i+1,off);
stripleft.setPixelColor((stripleft.numPixels()-i)-1,off);
stripleft.setPixelColor((stripleft.numPixels()-i)-2,off);
i++;
///// adds new color to the arrays
void addnewcolor(){
if((stripright.numPixels()/2)%2){
top_arrayright[half-1] = colorright;
top_arrayright[half] = colorright;
bottom_arrayright[half-1] = colorright;
bottom_arrayright[half] = colorright;
}else{
top_arrayright[half-2] = colorright;
bottom_arrayright[half-2] = colorright;
if((stripleft.numPixels()/2)%2){
top_arrayleft[half-1] = colorleft;
top_arrayleft[half] = colorleft;
bottom_arrayleft[half-1] = colorleft;
bottom_arrayleft[half] = colorleft;
}else{
top_arrayleft[half-2] = colorleft;
bottom_arrayleft[half-2] = colorleft;
///// shifts the array over two
void shifttwo(){
for(byte i=0;i<half;i++){
top_arrayright[i] = top_arrayright[i+2];
bottom_arrayright[i] = bottom_arrayright[i+2];
}else{
////// if even //////////
for(byte i=0;i<(half-1);i++){
////// if odd /////////////////////////
top_arrayleft[i] = top_arrayleft[i+2];
bottom_arrayleft[i] = bottom_arrayleft[i+2];
}else{
///controls how fast the pixels turn off from the center
void drop(){
//// controls the drop rate of the bars that are lit up ///////////
if((lastleft>left)&&(lefttimer1<=(millis()-analogRead(droprate)))&&(lefttimer2 <(millis()-20))){
lastleft = lastleft-1;
lefttimer1 = millis();
lefttimer2 = millis();
}else if(lastleft<left){
lastleft = left;
lefttimer2 = millis()+20;
/////// controls the drope rate of the right bar
if((lastright>right)&&(righttimer1<=(millis()-analogRead(droprate)))&&(righttimer2 <(millis()-20))){
lastright = lastright-1;
righttimer1 = millis();
righttimer2 = millis()+20;
}else if(lastright<right){
lastright = right;
righttimer2 = millis();
/// takes audio and turns it into a usable number
void bars(){
left = analogRead(leftChannel); // read the left audio channel
right = analogRead(rightChannel); // read the right audio channel
left = pow(left,1.2);
right = pow(right,1.2);
int sensitivity = map(analogRead(sensitivityinput),0,1023,418,100); // gets and sets senitivity rang
int minimum = map(analogRead(flux),0,1023,0,(sensitivity-1)); // gets and sets the minimum audio input needed to light first bar
////////////////////// set limits on left ///////////////////
if(left>sensitivity){
left = sensitivity;
}else if(left<minimum){
left = minimum;
////////////////////// sets limits on right //////////////////
if(right>sensitivity){
right = sensitivity;
right = minimum;
//uses the syntax above and sets a value to represent how meany bars to be lit up
right = map(right,minimum,sensitivity,0,half);
left = map(left,minimum,sensitivity,0,half);
centeractive.ino (6.95 KB)
prototypevumetter1_000.ino (3.69 KB)
Adafruit_NeoPixel.cpp (40.8 KB)
Adafruit_NeoPixel.h (3.16 KB)
