Hello All,
My requirement is, i have a load (LED) and it needs to be working in direct power from socket. And parallel socket power will be charging my battery. and once the power from socket is cut off, circuit should run from battery. it is working as expected. but the problem is, during switching from main power to battery power, LED turn off and On for a second. this will cause issue in my project. is there any way to solve this problem? suggestions are welcome.
also if some have tested circuit to meet my requirement pls post the same.
