Hi
Im new to arduino and Im trying to use it for my undergrad project which is an RFID doorlock with Data Logging.
Im using 125Khz RFID reader (passive tags)
and an arduino clone i made with an atmega8L MCU..
I'll be using a servo motor to drive a deadbolt lock.
Im using a RFID reader kit and will use its tx for reading the tags..
Im on the process of developing the code and I know it is a common project
THe first thing you should do is write some use cases, small stories how the system is used, and what it does.
Use case 1 - the trusted person
1.1 person takes RFID card and holds it near the reader.
1.2 The door opens.
Under the hood a lot of steps happen
a) The card is read into the system.
b) The number is compared against known numbers
c) The number is written to the log together with a time stamp
d) The servo opens the door
e) after 10 seconds the servo closes the door
f) wait for next card
There are several more usecases - the untrusted person - the person without a card - add a trusted number - remove a trusted number - read logfile - clear logfile - ....
From writing these usecases down you get a precise feeling what the system should do in what order. Furthermore it becomes clear what kind of datastructures / classes you might need - A clock - A list of trusted numbers etc.
Each type of RFID reader has different output. You'll need to know how much data your RFID reader outputs, in what format, in order to read that data. You didn't define which RFID reader you are using, so we can't help you.
The process for logging the data depends on where you are logging the data. PC? SD card? Ethernet? You didn't say, so, no help there, either.
None of what you are doing is particularly challenging, except using a home-made microcontroller. There are plenty of examples on the web.
Develop one functionality at a time. Read the RFID card. Write some nonsense to a log. Randomly spin the servo.
When each piece works, as a function, it will be trivial to call the functions in the correct order to open the lock and log that activity.
I'm working on a complete home system where my RFID tags would be stored and translated on a central server, but I found this device that i'm going to play around with and worst case scenario i have an rfid reader and nice magnetic door lock.
What if someone keeps the door open long enough that you think you should timeout and lock the door, but it's not actually shut?
If you have a closed sensor, what if the door is half-closed, so the sensor is triggered, but the servo cannot actually push the deadbolt in?
I think these cases are some reasons why many doorlocks use a sprung latch bolt with a solenoid actuator.
