I wish to return a pointer to a structure from a function within a class, but I can’t seem to find the right syntax/signature to get it to compile. I’ve searched these forums, and googled it, and the way I am typing it looks correct, and I’ve experimented with where to place the *'s and get compile errors no matter what.
I made a simple test project just to try and figure it out, which I have posted below. I have a class, which is mostly a wrapper for a structure. The structure is a private member of the class. I have a function gettmPtr() which is supposed to return a pointer to that private structure. Yes, I realize it would be much simpler to just make the structure public. Yes, I realize what I’m trying to do is a bit screwball and not exactly good programming practice. Please don’t preach at me about that, I’ve been programming in other languages for 30 years. My ‘real’ project is much bigger than the testbed posted below, with many classes, many structures, and many complex functions. My purpose for returning a pointer to the structure rather than making it public is to force a level of abstraction. Oh yes, and I know about the standard time.h library.
The line at issue is near the end of the DateWiz.cpp file.
StructReturnTest.ino
// * * * * Structure Return Test * * * *
// File: StructReturnTest.ino
// (u) uncopyright 2014 Dr. Wizard, except where noted.
#include <stdint.h>
#include "DateWiz.h"
class date_d date1(22,6,1963);
struct tmd* tmP;
struct tmd tmC;
tmP = date1.gettmPtr();
tmC = date1.gettmCopy();
date1.setMonth(8);
Serial.println(tmP->tm_month);
Serial.println(tmC.tm_month);
} // END setup()
} // END loop()
DateWiz.h
// File: DateWiz.h
#include <stdint.h>
#ifndef _DATEWIZ_H
#define _DATEWIZ_H
// STRUCTURES //
struct tmd {
uint8_t tm_mday; // Day of the Month 1-31
uint16_t tm_year; // Years 1900-2100
uint8_t tm_month; // Month number 1-12
// CLASSES //
// date_d Class //
class date_d {
public:
// Constructors, Destructor
date_d();
date_d(uint8_t dayOfMonth, uint8_t month, uint16_t years);
// Member GET functions
uint8_t getDayOfMonth();
uint8_t getMonth();
uint16_t getYear();
// Member SET functions
void setDayOfMonth(uint8_t days);
void setMonth(uint8_t months);
void setYear(uint16_t years);
// Other GET functions
struct tmd gettmCopy();
struct tmd* gettmPtr();
private:
struct tmd _tmd;
}; // END date_d class definition
#endif
DateWiz.cpp
// File: DateWiz.cpp
#include <stdint.h>
// date_d Constructors, Destructor //
date_d::date_d() {
// Constructor with NO parameters Defaults to the Unix Epoch - Jan 1st, 1970
_tmd.tm_mday = 1; // Day of the Month 1-31
_tmd.tm_year = 1970; // Years since 1900 0-255
_tmd.tm_month = 1; // Month number 1-12
} // END constructor date_d()
date_d::date_d(uint8_t days, uint8_t months, uint16_t years) {
_tmd.tm_mday = days; // Day of the Month 1-31
_tmd.tm_month = months; // Month number 1-12
_tmd.tm_year = years; // Full year number 0-? (such as 2014)
} // END constructor date_d(uint8_t seconds, uint8_t minutes, uint8_t hours, uint8_t days, uint8_t months, uint16_t years)
// date_d Member GET functions //
uint8_t date_d::getDayOfMonth() {
return _tmd.tm_mday;
} // END getDayOfMonth
uint8_t date_d::getMonth() {
return _tmd.tm_month;
} // END getMonth
uint16_t date_d::getYear() {
return _tmd.tm_year;
} // END getYear
// date_d Member SET functions //
void date_d::setDayOfMonth(uint8_t days) {
} // END setDayOfMonth
void date_d::setMonth(uint8_t months) {
} // END setMonth
void date_d::setYear(uint16_t years) {
} // End setYear
// date_d Other GET functions //
struct tmd date_d::gettmCopy() {
return _tmd;
} // END gettmCopy
struct tmd* date_d::gettmPtr() {
return _tmd*; // error: expected primary-expression before ';' token
} // END gettmPtr
Thanks in advance for your help!
