Need testers for a new IDE
Thought I would try this as I need some functionality which I cannot get with standard IDE. (Win 7/64 bit & Arduino UNO) Getting quite a few compile warnings regarding HardwareSerial. Does not stop the sketch running though!
I really need to be able to "cut" from the Serial terminal output, for debugging/documentation purpose. Unfortunatily, ArduinoX does not do that at this time! Will it be able to in the future? I will keep an eye on this development, as the standard IDE is not all that good!
I tried to compile and get the following error message:
-do-compile:
[javac] Compiling 21 source files to /Users/reivilo/Downloads/arduinox-master/build/classes
[javac] javac: invalid target release: 1.7
[javac] Usage: javac
[javac] use -help for a list of possible options
There was another nice project called Cocoduino (forum, GitHub).
Are you using the same approach based on ino (website, GitHub)?
You can even use Xcode, the excellent and free IDE provided with every Mac. Check the embedXcode project (website, download, forum!
You must have Java 7 installed to compile it. I've switched to Java 7 because it's identical across all platforms now that the builds are provided directly by Oracle/Sun instead of Apple.
If you just want to try it out, download the pre-built version here:
http://hudson.joshy.org:9001/job/ArduinoX/lastSuccessfulBuild/artifact/dist/
avenue33: I tried to compile and get the following error message:
-do-compile: [javac] Compiling 21 source files to /Users/reivilo/Downloads/arduinox-master/build/classes [javac] javac: invalid target release: 1.7 [javac] Usage: javac [javac] use -help for a list of possible options
I’ve put up a new build here:
This improves compiler output and now uses a proper temp directory. Does this fix the issue?
  • J
Graynomad:
Does c:\tmp not exist on your computer?
The folder exists and has a subfolder names “blah” but no files.
Can you send me some console logs?
LIke this you mean?
ResourceManager resource configuration:
  • Resource category: JAVA
  • Current directory: C:\ArduinoX\win\
  • Property count: 18
  • Property:  =<>
  • Property: arguments=<>
  • Property: bundledvm=
  • Property: classpath=<lib\ArduinoX.jar;lib\RXTXcomm.jar;lib\arduinocompile.jar
    ;lib\jsyntaxpane-0.9.6.jar;lib\swing-layout-1.0.4.jar;lib\XMLLib.jar>
  • Property: currentdir=<${EXECUTABLEPATH}>
  • Property: embedjar=
  • Property: javapropertiescount=<1>
  • Property: javaproperty_name_0=<java.library.path>
  • Property: javaproperty_value_0=<./lib>
  • Property: jvmsearch=
  • Property: mainclassname=<com.joshondesign.arduinox.Start>
  • Property: maxversion=<>
  • Property: minversion=<1.6>
  • Property: skel_Debug=<1>
  • Property: skel_JniSmooth=<0>
  • Property: skel_PressKey=<1>
  • Property: skel_SingleInstance=<0>
  • Property: skel_SingleProcess=<1>
    Main class: com.joshondesign.arduinox.Start
    Currentdir: C:\ArduinoX\win
    Now searching the JVM installed on the system…
    JVM Lookup: found VM (V(1)(6)(0)) in registry.
    JVM Lookup: Env-Var JAVA_HOME not defined on this system.
    JVM Lookup: Env-Var JRE_HOME not defined on this system.
    JVM Lookup: Env-Var JDK_HOME not defined on this system.
    Found a vm bundled with the application: (jre)
    Current directory is C:\ArduinoX\win
    Running now <C:\ArduinoX\win\jre><><0.0.0>, instanciate=no
    Launching <C:\ArduinoX\win\jre><><0.0.0>
    RuntimeLibPath used: C:\ArduinoX\win\jre\bin\client\jvm.dll
    No version, trying with 1.6.0
    Saving jnismoothjar in C:\Users\Rob\AppData\Local\Temp\temp4.jar
    Created temporary filename to hold the jar (C:\Users\Rob\AppData\Local\Temp\temp
    4.jar)
    ClassPath element is C:\ArduinoX\win\ + lib\ArduinoX.jar
    ClassPath element 0=C:\ArduinoX\win\lib\ArduinoX.jar
    ClassPath element is C:\ArduinoX\win\ + lib\RXTXcomm.jar
    ClassPath element 1=C:\ArduinoX\win\lib\RXTXcomm.jar
    ClassPath element is C:\ArduinoX\win\ + lib\arduinocompile.jar
    ClassPath element 2=C:\ArduinoX\win\lib\arduinocompile.jar
    ClassPath element is C:\ArduinoX\win\ + lib\jsyntaxpane-0.9.6.jar
    ClassPath element 3=C:\ArduinoX\win\lib\jsyntaxpane-0.9.6.jar
    ClassPath element is C:\ArduinoX\win\ + lib\swing-layout-1.0.4.jar
    ClassPath element 4=C:\ArduinoX\win\lib\swing-layout-1.0.4.jar
    ClassPath element is C:\ArduinoX\win\ + lib\XMLLib.jar
    ClassPath element 5=C:\ArduinoX\win\lib\XMLLib.jar
    VM Created successfully
    DLL Setup on 1.6.0
    Classpath: -Djava.class.path=C:\Users\Rob\AppData\Local\Temp\temp4.jar;C:\Arduin
    oX\win\lib\ArduinoX.jar;C:\ArduinoX\win\lib\RXTXcomm.jar;C:\ArduinoX\win\lib\ard
    uinocompile.jar;C:\ArduinoX\win\lib\jsyntaxpane-0.9.6.jar;C:\ArduinoX\win\lib\sw
    ing-layout-1.0.4.jar;C:\ArduinoX\win\lib\XMLLib.jar;
    Option added:-Djava.library.path=./lib
    VM 1.2+ Created successfully !!
    Looking up for class <jsmooth/Native>
    Result code on DLL: 1
    Looking up for class <com/joshondesign/arduinox/Start>
    Looking up for class <java/lang/String>
    Invoke Static main ([Ljava/lang/String;)V
    the toolchain path = null
    WARNING:  RXTX Version mismatch
            Jar version = RXTX-2.2pre1
            native lib Version = RXTX-2.2pre2
    resources dir = C:\ArduinoX\win\resources
    parsing: C:\ArduinoX\win\resources\hardware\boards\diecimila.xml
    parsing: C:\ArduinoX\win\resources\hardware\boards\mega2560.xml
    parsing: C:\ArduinoX\win\resources\hardware\boards\uno.xml
    basedir = C:\ArduinoX\win\resources\examples
    Loaded settings: 3
    Nov 20, 2012 10:50:08 PM jsyntaxpane.DefaultSyntaxKit loadConfig
    INFO: unable to load configuration for: class jsyntaxpane.syntaxkits.CSyntaxKit
    from: jsyntaxpane/syntaxkits/CSyntaxKit/config.properties
    installing font: java.awt.Font[family=Courier New,name=Courier New,style=plain,s
    ize=12]
    prop = componentPopupMenu
    prop = document
    preferred size = 26.0
    prop = editorKit
    prop = background
    prop = caretColor
    prop = selectionColor
    ize=12]
    prop = font
    preferred size = 28.0
    prop = font
    prop = ancestor
    prop = ancestor
    saved settings to : C:\settings.properties
    serial port = COM11
    serial port = COM11
This is from an invocation after using the app with a maximised window. It came up at the standard small size.
______
Rob
Thank you!
